how to increase the actinic lights on time?
Bogdan
How do I increase the light time for actinic light. Right now the difference is 30 min. that is the actinic are on 30 min before std. lights and off 30 min after the std. lights. I want to increase the difference to 60 min. I understand that it can't be done via the portal. Only the timing for std. lights can be change on portal. The MH lights setting do nothing. I guess I need to get into the program to change the default 30min to 60min. How do I do that, I don't even remember how to get into the program on the arduino. Can you help?
You can change the offset on the portal in the same window..
Bogdan
On the portal click on Internal Memory, then under lighting. It shows the standard light time an the Actinic offset..
Bogdan
Re: how to increase the actinic lights on time?
Well I do not have WiFi attachment so it doesn't work. I was thinking about the RA Client rather sorry for misleading.
Try ReefAngel.InternalMemory.ActinicOffset_write(60); put whatever number you need.
