Resolution of RF Vortech command
dedvalson
Re: Resolution of RF Vortech command
Would you like me to take a look at doing this?
Don
Don
I'll try to get something put together over the weekend.
Try this one.
Use mode 12 (Short Pulse).
It is still using 8ms resolution.
The minimum pulse is 240ms, which would be duration=30.
dedvalson
So, more than six months later I finally get back to you on this. Life has been very busy.
Anyway, I downloaded and installed the 1.1 code above and tried running it in Short Pulse mode (12). It appears that it isn't much different from the previous version. The original modes still work fine, but the High Resolution modes (12-14) are sporadic, like we are still missing commands. In mode 12 the Vortech works fine if the duration is set to 30. But if I set it to 31, misses every 5th or 6th cycle.
So it works, but is not regular, it is sporadic.
Don
Don
dedvalson
It also appears that mode 14 does not work at all. It just turns on and stays on.
Don
Don
Just to try to replicate the same stuff, which libraries version are you running?
dedvalson
It looks like 1.0.7.
I can easily change that if it would help.
Don
Don
I did not have time to look into this and test yet, but I'm pretty sure it is because of the Radion integration.
Can you try commenting line 791 on ReefAngel.cpp??
https://github.com/reefangel/Libraries/ ... l.cpp#L791
dedvalson
You were right. That Fixed Mode 12 (and Probably Mode 13, I didn't test it). But Mode 14 is still totally dead.
This is great, now I can make big waves in the aquarium.
I would love to get 14 going though. If you would like, I can help with that.
Don
Don
14 is long wave. Isn't the original 4 good enough?
It doesn't need the same precision as the 12, right?
I've logged the issue for the Radion integration
https://github.com/reefangel/Libraries/issues/99
dedvalson
13 is long pulse, 14 is NTM, at least that is what you had said earlier. I was hoping for an accurate NTM.
dedvalson
Duration is 68, Speed is 70, Mode is 14.
dedvalson
Any progress on this
dedvalson
If you would like me to, I could look at the firmware for the RF module and see if I can fix this.
Don
Don
I'll try to check over the weekend.
Without a RF sniffer, you won't get far
Try this one.
