Just like the title says. Have tried putting it in tap water, rodi, new NSW, always 6.99. Tried power cycling, no luck.
Ph won't read anything other than 6.99
Not yet, I'm out of packets but I just calibrated a few months ago. Is this normal?
I think the change might have happened when I updated my libraries. Would this cause a deletion of calibration?
ReefAngel.FeedingModePorts = Port2Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.SingleATOLow( Port1 );
ReefAngel.DayLights( Port3 );
ReefAngel.Wavemaker1( Port5 );
ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port3 ) );
ReefAngel.StandardHeater( Port8 );
ReefAngel.Portal( "mineman@mac.com" );
Re: Ph won't read anything other than 6.99
Let's try this:
ReefAngel.PHMin=550;// 550=PH7.0
ReefAngel.PHMax=830;// 830=PH10.0
