Multiple RA's in one house
Ask in here.
rossbryant1956
Post by rossbryant1956 »
I have a friend that has four 300 gallon tanks in his house and I'd like to get them all on Reef Angel. Two of them are close enough to share a unit but the other two are not. How would I configure the wifi unit(s) to be able to monitor those RA units separately? Each wifi would grab their own IP, but would I use different ports for each so I get each tank out on the portal? Thanks in advance.
Re: Multiple RA's in one house
Yes, different ports.
wolfador
Post by wolfador »
Just to add a bit more information incase any one else is wondering how. This would be configured in your "router"
RA1 <-Internal IP:port-> 192.168.1.10:9000 <-External IP:Port-> 68.125.120.72:9000 (example ip's)
RA2 <-Internal IP:port-> 192.168.1.11:9000 <-External IP:Port-> 68.125.120.72:9001
RA3 <-Internal IP:port-> 192.168.1.12:9000 <-External IP:Port-> 68.125.120.72:9002
You could also mess with the wifi settings to change the default port but I would just leave it standard and configure it in your firewall/router.
John
ReefAngel and ReefAngel-HD developer
If the RA iOS app has helped please consider a donation
wolfador wrote:You could also mess with the wifi settings to change the default port but I would just leave it standard and configure it in your firewall/router.
+1 That would be my recommendation as well.
rossbryant1956
So you are saying leave the RA wifi settings standard (port 2000 or whatever) and then map outside IP's individual incoming port(s) to a particular ip address and standardly assigned port on the inside? Thx
Yeah, and you should be able to point your phone app to the external ip/dns and it should work inside your net or out.
That's what I do on my home network with my 2 test units.
dapg8gt
Post by dapg8gt »
Longshot but by chance does anyone know how I would accomplish this on A XFINITY Cisco DPC3941T Gateway? Still early in my exploring the new unit I'm calling it a night now but thought I'd let this soak for a bit before I stress out some more tomorrow night =)..
Daniel
