Hi guys , I've just install a 1.5HP aircon compessor with contactor. The moment I plug in the contactor into the relay box , the compressor will imm cuts in . Even when I use the temp control it will just cuts in and not cuts out. Even with Ports that are not in use. Only will cuts out when I unplug it.
Do u think that I have a faulty relay box or?
aircon compressor chiller
Dracula
Re: aircon compressor chiller
Hi Roberto
my guess it's the open neutral instead of hot on the relay box even when the port is off ( as mention in 1 of the previous thread ) Thus it keeps running the chiller when it's plug in
how safe it is if I were to follow the way in the thread above if I open up the relay box and just swop the cables?
How old is your relay box?
There were just a few open neutral boxes made a while ago.
But, no matter which one, the contactor would've shut down.
Which contactor are you using?
