I can't seem to get my PH probe working correctly. I'm running an RAGen PDE and I go in to the PH Calibration menu. I then stick the probe in the 7.0 solution, wait for it to stabilize (~300) and then repeat with the 10.0 solution. Once it's stabilized (~615) I click OK and it just won't save the new settings. The PH readings are still way off (5.xx) so I'll go rich back in to the PH Calibration menu and it's back to some completely different numbers (like 388 and 398).
I've tried it several times and made sure I selected OK to save and not CANCEL. I even tried selecting CANCEL once as a may-as-well-try-it. What am I missing?
PH probe calibration help
Re: PH probe calibration help
I had the exact same problem and my fix was sent to me by Roberto, he told me to insert the follow lines in my sketch after the ReefAngel.int command.
ReefAngel.PHMin=368;
ReefAngel.PHMax=655;
Use the numbers from your calibration solution.
It work for me I'd bet it will work for you.
good luck
Don
good luck
Don
I just looked at the code. Once you calibrate and choose OK to save, you need to reboot the controller (power cycle it) for the new values to be read in.
I'm going to work on correcting this so the values are used immediately instead of on reboot only.
How do you power cycle the controller? Just unplug it or is there a restart button somewhere?
Yeah, you just unplug it and plug it back in.manoverboard wrote:How do you power cycle the controller? Just unplug it or is there a restart button somewhere?
I ended up splitting the code for the PH calibration.
I have a menu for pH 7.0, and a separate one for pH 10.0.
Also, instead of a simple min/max, I use the average of the last 2 reads.
The main reason is that the probe value seems to jump around a bit.
Partly an accuracy issue. The min/max will capture those jumps, where you really
want an average.
But more of an issue when switching between fluids, especially if you want to clean
of the old fluid off.
And perhaps most importantly, it takes time, so I would rather just do one at a time.
want an average.
