Error Uploading
tiberian
Error Uploading
Post by tiberian »
We just got the controller today and I have spent hours trying to get it set up. Unfortunately, I keep getting an "error updating" error.
Things I have tried:
-re-installing the RA software
-re-installing drivers & RA software
-re-booting computer
-changing usb ports
-unplugging everything but the power and usb cable from the controller
-turning off my firewall (norton 360)
Board selected = Reef Angel Controller with optiboot
COM3 is the only one appearing as active
Below is the error code...what am I doing wrong? The controller does re-boot (screen goes dark, status light blinks) when it gets to that part of the upload, but then it says "Error Uploading".
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 6,812 bytes (of a 32,256 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\Meredit\AppData\Local\Temp\build125967453092416192.tmp\InitialInternalMemory.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean,
Using Port : \\.\COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude done. Thank you.
Re: Error Uploading
Did you purchase the standard RA or RA+?
tiberian
Re: Error Uploading
Post by tiberian »
Standard RA
Re: Error Uploading
Can you post a photo of how the cable is connected to RA?
tiberian
Re: Error Uploading
Post by tiberian »
Certainly.
tiberian
Re: Error Uploading
Post by tiberian »
Roberto, I got your PM and have downloaded the software, but there doesn't seem to be an option to reply to your PM. If I go to compose it says I am too new. :)
Is there another way to get it to you, or do I have to post it here?
Thank you for your help!
Re: Error Uploading
You should be able to respond to pm now.
I think it is more than 3 posts minimum.
Paulweck
Re: Error Uploading
Post by Paulweck »
i also am having the same issue can we please post the fix
Re: Error Uploading
Can you post the error you are getting?
Do you have RA or RA+?
Paulweck
Re: Error Uploading
Post by Paulweck »
i have the RA+ pvm. when trying to upload my code via the wizard sometimes i get the error COM3 the other times it just gives me a SIMPLE error no code affiliated
Re: Error Uploading
Did you change to Reef Angel Plus Controller under Tools->Board?
Paulweck
Re: Error Uploading
Post by Paulweck »
yes i did im still getting the error thanks for your help by the way
Re: Error Uploading
Can you copy and paste the errors in red you are getting??
Not the wizard error.... Try to upload any code...
Paulweck
Re: Error Uploading
Post by Paulweck »
when trying to verify the is what it reads
Watchdog Timer
Version Menu
Simple Menu
core.a(main.cpp.o): In function `main':
C:\Program Files (x86)\Reef Angel Controller\hardware\arduino\cores\arduino/main.cpp:11: undefined reference to `setup'
C:\Program Files (x86)\Reef Angel Controller\hardware\arduino\cores\arduino/main.cpp:14: undefined reference to `loop'
Paulweck
Re: Error Uploading
Post by Paulweck »
heres the what i get when trying to upload a pre-loaded code \
Watchdog Timer
Version Menu
Dimming Signal
Date/Time Setup Menu
Standard Menu
Binary sketch size: 38,738 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM3 -b115200 -D -Uflash:w:C:\Users\paul\AppData\Local\Temp\build5120656404065021473.tmp\RA_Preloaded.cpp.hex:i
Using Programmer : stk500v2
avrdude: Recv: . [1b]
avrdude: Recv: . [01]
avrdude: Recv: . [00]
avrdude: Recv: . [0e]
avrdude: Recv: . [14]
avrdude: stk500v2_getsync(): can't communicate with device: resp=0x01
Re: Error Uploading
Does the controller reboot a few seconds after you hit upload?
Right when the "Rebooting Reef Angel Controller" message shows in the screen.
Paulweck
Re: Error Uploading
Post by Paulweck »
no it does not
Re: Error Uploading
Can you take a photo of the usb-ttl cable connector? The one with several colors at the end?
Paulweck
Re: Error Uploading
Post by Paulweck »
here it is
sorry its a link the forum wont let me upload the picture
http://i241.photobucket.com/albums/ff19 ... ac25a0.jpg
Sebyte
Re: Error Uploading
Post by Sebyte »
It looks like you have it plugged into the wrong pins, although it is not that clear in the pic. The plug should be biased to the right not the left, i.e. the black lead should go to the right most pin.
Sebyte
Re: Error Uploading
Post by Sebyte »
Just taken a second look and you are connected correctly. I initially had problems by missing the end pin.
smoothdog
Re: Error Uploading
Post by smoothdog »
I am getting this error when trying to upload the InitialInternalMemory on my new RA+. I have selected the correct board, the correct COM port and Checked the cable at least 3 times to make sure it is plugged in properly (black wire to the outside right pin):
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 7,420 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM5 -b115200 -D -Uflash:w:C:\Users\SMOOTH~1\AppData\Local\Temp\build9041109765076733720.tmp\InitialInternalMemory.cpp.hex:i
Using Port : \\.\COM5
avrdude: Recv:
Re: Error Uploading
Does the controller reboot?
smoothdog
Re: Error Uploading
Post by smoothdog »
No, it does not.
smoothdog
Re: Error Uploading
Post by smoothdog »
I tried installing the software on a different computer thinking that there may have been some kind of issue with my desktop running Vista Ultimate 64bit. Installed on my old laptop running xp and I'm getting the exact same error so it's likely either a bad cable or controller board. :(
smoothdog
Re: Error Uploading
Post by smoothdog »
Roberto, I don't have enough posts yet to reply to your pm. I sent you an email earlier from the address I used to place the order. It's an swbell dot net email address.
Re: Error Uploading
smoothdog wrote:Roberto, I don't have enough posts yet to reply to your pm. I sent you an email earlier from the address I used to place the order. It's an swbell dot net email address.
You should have enough posts now. :)
dnastynice
Re: Error Uploading
Post by dnastynice »
hmmm i had trouble the other day trying to redo my RA+ using the wizard. it wouldnt upload error plz try again. Going to spend more time today fiddling with it. I may need some help today 8/
smoothdog
Re: Error Uploading
Post by smoothdog »
Roberto sent a new cable and all is well now. Great customer service, thanks for the quick response Roberto!
mason dixon
Re: Error Uploading
Post by mason dixon »
I've got the same problem. How do I get a new cable?
