Time and date resseting
Wolfy000
I disconnect the power to the unit and I lose the date and time I have. Is this a code issue? I have the Reefplus board. Also how do I upload my code straight to memory? I used the wizard to generate part of the code and I added a few bits here and there.
I had an issue with the battery holder inside the ra. One contact needed to be resoldered.
Re: Time and date resseting
Use Arduino to upload your code now.
File->Upload
Can you check if the battery is drained?
It should be 3V.
File->Upload
It should be 3V.
