sketch_Mine:109: error: expected constructor, destructor, or type conversion before '.' token
sketch_Mine:110: error: expected constructor, destructor, or type conversion before '.' token
sketch_Mine:111: error: expected declaration before '}' token
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 801 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.PWM.SetChannel(1,TunzeLongPulse(30,87,2,true));
ReefAngel.PWM.SetChannel(0,TunzeLongPulse(30,87,2,true));
ReefAngel.StandardHeater( Port7,740,780 );
ReefAngel.StandardFan( Box1_Port2,780,781 );
ReefAngel.StandardFan( Box1_Port3,780,781 );
ReefAngel.DosingPumpRepeat( Box1_Port5,0,60,10 );
ReefAngel.DosingPumpRepeat( Box1_Port6,0,60,10 );
ReefAngel.PWM.SetDaylight(PWMSlope(11,30,21,0,0,70,180,0));
ReefAngel.PWM.SetActinic(PWMSlope(11,0,22,0,0,90,180,0));
byte TunzeLongPulse(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
byte tspeed=0;
PulseMinSpeed=constrain(PulseMinSpeed,0,100);
PulseMaxSpeed=constrain(PulseMaxSpeed,0,100);
tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
if (PulseSync)
return tspeed;
ReefAngel.Portal( "xtown90" );
int x,y;
// Salinity
ReefAngel.LCD.DrawOutletBox( 12, 75, TempRelay );
// Relay Expansion
