Make sure you use memory location 276 - ATOExtendedTimeout
All functions are using this location and the others were deprecated starting on library 1.0.0
Ato timeout problem
Re: Ato timeout problem
I'm assuming you are using latest 1.0.1 libraries, right?
What values do you get when you use RA Status to read memory location 276?
dbmet
Just curious was your ATO working before? Has it ever worked?
How are you floats setup?
Yeah, but if you are using hard coded settings, it will ignore any memory setting.
