Ato timeout problem
Re: Ato timeout problem
Make sure you use memory location 276 - ATOExtendedTimeout
All functions are using this location and the others were deprecated starting on library 1.0.0
I'm assuming you are using latest 1.0.1 libraries, right?
What values do you get when you use RA Status to read memory location 276?
Which function are you using?
Can I see the code?
You can't use memory settings if you hardcode your settings.
Are you sure?
The code about should give you 60 seconds timeout.
dbmet
Post by dbmet »
Just curious was your ATO working before? Has it ever worked?
How are you floats setup?
Yeah, but if you are using hard coded settings, it will ignore any memory setting.
