Error uploading Wifi Setup
cjrudy
I set up the Wifi attachment with no problem but I am trying to upload the wifi set up to the RA controller and keep getting error, any thoughts ?
Re: Error uploading Wifi Setup
If your wifi attachment is already setup, you won't need to upload the wifisetup code.
Basically, there are 4 choices to set it up:
1. Using Push-Button
2. Wifi Utility
3. Wifi Setup code
4. Manually
You can pick any of the choices. Once it is setup, you don't need to do any of the others.
2. Wifi Utility
3. Wifi Setup code
4. Manually
cjrudy
got it, thanks, although it still seems as if I cannot upload any code
