T1,T2 and T3 Error
cjrudy
T1,T2 and T3 Error
Setting up my Reef angel for the first time (Xmas present from the wife) and I am getting errors on T1, T2 and T3. I tried plugging the temperature probe into each with the same result.
rossbryant1956
Re: T1,T2 and T3 Error
plug them in and then reset the RA. (unplug and plug back in)
rossbryant1956
be very careful with those temp probe plug ends, they are very fragile!
cjrudy
That did it thanks, connection is kind of touchy though.
cjrudy
The temp probe constantly errors out, it will stay on for a bit, then go off. Sometimes the only way to get it back on is to constantly reset. This is a pain
Do the wires inside the white connector look ok or they look stripped?
How many probes do you have?
cjrudy
I have a single temp probe, the wires look fine.
Maybe you got a bad one.
Try moving it to a different port or see if the problem is a bad connection inside the white plug.
If that doesn't work, PM me for RMA number
