ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 290 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.DelayedOn( Port3,180 );
ReefAngel.Wavemaker( Port5,30 );
ReefAngel.Wavemaker( Port6,60 );
ReefAngel.PWM.SetChannel( 0, PWMSlope(5,30,22,0,10,45,240,10) );
ReefAngel.PWM.SetChannel( 1, PWMSlope(5,30,22,0,10,45,240,10) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(5,30,22,0,10,45,240,10) );
ReefAngel.PWM.SetChannel( 3, PWMSlope(5,30,22,0,10,40,240,10) );
ReefAngel.PWM.SetChannel( 4, PWMSlope(9,0,22,0,10,60,240,10) );
ReefAngel.PWM.SetChannel( 5, PWMSlope(9,0,21,30,10,25,240,10) );
ReefAngel.Portal( "Dracula" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
Lightning on demand
Lightning on demand
Hi Guys , sorry I've search thru the forum for this above funtion and tried to insert the standard PWM extension codes into mine but still fail to load it . Can anyone help me with this.
Re: Lightning on demand
Let's get the lightning first then we move to on-demand...
byte PWMChannel[]={
0,0,0,0,0,0};
PWMChannel[0]=PWMSlope(5,30,22,0,10,45,240,10);
PWMChannel[1]=PWMSlope(5,30,22,0,10,45,240,10);
PWMChannel[2]=PWMSlope(5,30,22,0,10,45,240,10);
PWMChannel[3]=PWMSlope(5,30,22,0,10,40,240,10);
PWMChannel[4]=PWMSlope(9,0,22,0,10,60,240,10);
PWMChannel[5]=PWMSlope(9,0,21,30,10,25,240,10);
CheckCloud();
ReefAngel.PWM.SetChannel( 0, PWMChannel[0] );
ReefAngel.PWM.SetChannel( 1, PWMChannel[1] );
ReefAngel.PWM.SetChannel( 2, PWMChannel[2] );
ReefAngel.PWM.SetChannel( 3, PWMChannel[3] );
ReefAngel.PWM.SetChannel( 4, PWMChannel[4] );
ReefAngel.PWM.SetChannel( 5, PWMChannel[5] );
int x,y;
x = 15;
y = 2;
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000001
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B000010
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
// let's go through all channels to pick which ones will be dimmed
for (int a=0;a<6;a++)
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
PWMChannel[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[a],0,180);
for (int b=0;b<6;b++)
if (bitRead(Daylight_Channels,b)==1)
else lightningstatus=0;
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
Thanks Roberto
I'll give it a try tonight
