Where to put additional code
jedimasterben
Post by jedimasterben »
Hello all! I just ordered my RA yesterday and can't wait to get it! I should have added the wifi and PWM dimming expansions, but some stuff on eBay hasn't sold yet, so they'll be about a week behind, but I will go ahead and get the programming down (hopefully, experts here willing :D) for all of it. In the future, the RF and salinity expansions will be coming, but all of that in due time.
A bit about my tank. It's 80g (48x24x16), and I've got two MP10wES in the tank for flow. I really wish I had repaired my third one instead of selling it off. Oh well. My sump is a 40B (but probably gonna change it to a series of 10/20g tanks) with a section containing a powerful algae scrubber and the other section housing about 20 gallons of macros. All is LED-lit, the main tank has a four-channel full spectrum array run on Meanwel ELN-60-48P, and the algae scrubber and fuge have deep red/royal blue based arrays run on Meanwell LPC-35-700. I'm also running a reactor for Purigen and Rox 0.8 carbon.
I went ahead and generated a code via the RA Wizard, and here's what I got:
    ReefAngel.LightsOnPorts = Port7Bit;
    ReefAngel.StandardATO( Port2,300 );
    ReefAngel.StandardLights( Port3,21,0,9,0 );
    ReefAngel.StandardLights( Port4,18,0,12,0 );
    ReefAngel.DosingPumpRepeat( Port5,0,60,60 );
    ReefAngel.DosingPumpRepeat( Port6,30,60,60 );
    ReefAngel.StandardLights( Port7,6,0,21,0 );
    ReefAngel.DosingPumpRepeat( Port8,0,30,60 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,19,0,12,60,12) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(8,0,21,0,12,100,12) );
    ReefAngel.PWM.SetChannel( 2, PWMParabola(9,0,19,0,12,75,12) );
    ReefAngel.PWM.SetChannel( 3, PWMParabola(8,0,20,0,12,100,12) );
    ReefAngel.Portal( "jedimasterben" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
There are a few things that I want to add on top of that, but, frankly, I'm not sure how. I'd say I'm tech savvy, but when it comes to Arduino code, I know pretty much nothing.
I would like to rename the ports on the relay so I can remember which is which. :)
I would like to do sunrise/sunset based on location. I'd like to use the sunrise/sunset times for the Great Barrier Reef, but adjusted for my time zone (so length of day is the same as the GBR). (I can't post links or I'd link the thread)
I would like to do weather effects with clouds on all channels but lightning only on channels 0 and 2, if that's possible.
I would like to do moon phase using one of the RA moonlight units (I think that is built in to the code I have above, maybe?)
I would like to have the option to force cloud cover and a storm from the menu.
That's all I can really think of for now. If anyone can lend a hand in how to modify the existing codes for that stuff and where the code should go I'd appreciate it! This is all new to me and is very confusing!
Re: Where to put additional code
Welcome!!!
The port's don't show on the screen. Only numbers.
There has been a couple people that created custom screens with names in it.
Here is one: http://forum.reefangel.com/viewtopic.php?p=11197#p11197
If you are talking about just in the code, we can do that too.
You can use something like this:
#define Reactor Port1
Then, you can reference the word Reactor as if it was Port1.
ReefAngel.Relay.On(Reactor);
jedimasterben
Thank you for your reply, Roberto, your legendary service is very much appreciated. :D
Ok, so no port names on the screen, I'm cool with that, as long as they show up in the Wifi interface it's all good!
Reef Angel in da house! :mrgreen:
Ok, a bit of a change of plans. I won't be getting the PWM expansion immediately, only the Wifi expansion, but it is on a 2 week backorder. If I go ahead and program the unit now without the code for the wifi, how hard is it to change the code once the wifi unit arrives? As easy as just plugging the unit back in and uploading the new code like normal?
This is what I have right now, with cloud/storms on the stock PWM channels:
#define Return pump Port1
#define ATS pump Port2
#define Scrubber light Port3
#define Fuge light Port4
#define Calcium doser Port5
#define Alk doser Port6
#define Food doser Port7
#define Main LED fan Port8
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit | Port8Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardLights( Port3,20,0,8,0 );
ReefAngel.DosingPumpRepeat( Port7,0,30,60 );
ReefAngel.StandardLights( Port8,6,0,22,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(8,0,20,0,12,80,12) );
ReefAngel.PWM.SetActinic( PWMParabola(7,0,21,0,12,100,12) );
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 50
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 30
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 3
#define Lightning_Change_per_Cloud 25
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if (lightningchance)
int x=0;
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
I would like to integrate this, though: http://forum.reefangel.com/viewtopic.php?f=12&t=1627 (still can't post links, but put a period in there)
I went to the last page and there were several things posted with a couple of files attached in a .cpp and a .h file, but I don't know what those are or how to implement them. AFAIK, it was written only for the PWM expansion channels and not the stock channels. Any advice as far as that goes?
Yeah, you can see the labels in any of the apps :)
I changed your code for you.
Here is the original thread:
http://forum.reefangel.com/viewtopic.php?f=14&t=288
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
  ActinicPWMValue=PWMParabola(8,0,20,0,12,80,12) ;
  DaylightPWMValue=PWMParabola(7,0,21,0,12,100,12);
  CheckCloud();
 ReefAngel.Portal("jedimasterben");
void CheckCloud()
#else
#endif
 if (cloudchance)
 if (cloudchance)
 DaylightPWMValue=0;
 ActinicPWMValue=0;
 delay(1);
 cloudindex++;
 int x=0;
 int x=0;
 cstart*=60;
 cend*=60;
I also already added the wifi stuff... It's just one line...
For the sunrise/sunset based on location, you should ask lnevo. I think he's got it on standard channels too.
jedimasterben
Again with that legendary service! :)
Thank you very much for fixing my code, I knew I was gonna mess something up in it lol. Once I grab some velcro to get the main unit stuck where it needs to be, I'll get this puppy rolling!
And I'll definitely ask Inevo, thanks!
The sunrise/sunset code doesn't do anything with any channel :)
The standalone code calculates times.
The post with the attachment has instructions for use. It's as easy as unzipping the class zip file in your Libraries folder and adding a few statements.
I'll take a look at your code tomorrow if you can't figure it out. Hard to paste code on an iphone. The required code is only 2-3 lines...
Here's a question for Roberto. Can you use the StandardLight memory locations with the PWM ports? If not, then you'll need to use the function calls in your PWM calls to get the rise/set hour and minutes.
See what you can figure out, and we'll get you all squared away tomorrow, maybe even later tonight.
Happy New Year!!!
After you get the class installed in your libraries, you can use these functions to get the sunrise and sunset. You can assign the results to variables and then plug them into your schedules where needed or call them directly inside your PWMParabola function.
sl.GetRiseHour();
sl.GetRiseMinute();
sl.GetSetHour();
sl.GetSetMinute();
Like this:
ActinicPWMValue=PWMParabola(sl.GetRiseHour().sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),12,80,12) ;
jedimasterben
lnevo wrote:The sunrise/sunset code doesn't do anything with any channel :)
Happy New Year!!!
Ok, I extracted the folder to the /libraries folder, I got that down, but when I look at your post here:
lnevo wrote:Here is the latest code with the additions mentioned above. At this point, it should be feature complete and has been running for a while with no issues.
Installation: Just unzip the attached zip file into your libraries folder. To use in your code all you need to do is the following:
// Add to includes
#include <SunLocation.h>
// Declare the object
SunLocation sl;
// In loop()
sl.CheckAndUpdate();
If you want to change the default coordinates from GBR:
// In setup
sl.Init(latitude, longitude) // In decimal numbers (i.e. -18.285833, 147.699722)
If you want to set your offsets:
sl.SetOffset(-9,0,-9,0); // rise_hour, rise_seconds, set_hour, set_seconds
If you use the default memory locations, you just need to declare the port for your Standard and Actinic lights as follows and the times will be set automatically
ReefAngel.StandardLights( Port1 );
ReefAngel.ActinicLights( Port2 );
If you are hard coding or using the variables for other functions you can get the calculated results with the following functions
sl.GetRiseHour();
sl.GetRiseMinute();
sl.GetSetHour();
sl.GetSetMinute();
Any questions on usage or improvements, feel free to discuss :)
and
lnevo wrote:After you get the class installed in your libraries, you can use these functions to get the sunrise and sunset. You can assign the results to variables and then plug them into your schedules where needed or call them directly inside your PWMParabola function.
sl.GetRiseHour();
sl.GetRiseMinute();
sl.GetSetHour();
sl.GetSetMinute();
Like this:
is where I get lost. I know the #include goes at the top with the rest of the #includes, but I really don't know where to put the rest of the stuff, or how to assign variables. I'd never even seen Arduino coding before I ordered the RA. :)
And then the offsets is where I change the time offset to my location, since I'm 16 hours behind the time at the GBR?
I will fill in your code when i get home.
What devices do you want based on sunrise/sunset?
What is your timezone?
jedimasterben
lnevo wrote:I will fill in your code when i get home.
You're awesome. :)
Just my lights. I can't think of anything else I'd need based on the time.
Timezone is EST (-5:00)
Happy new year!
Well, you have a lot of "lights"...Algae Scrubber and Fuge light...I didn't mess with those at all, but hopefully you can see how to adjust those if you want them based on the functions from SunLocation... if not, let me know I can help you there as well.
I set the offset to -13 hours so that it would match the longest light cycle you had which was your DayLight PWM... typically this is your Actinics btw.. if you ever wanted to use the Memory locations and utilize the ActinicOffset, you'd need to reverse your setup.
This will put your light's on tomorrow at 6:56am and off at 8:47pm with your Actinic's on one hour after sunrise and one hour before sunset. Keep in mind that we are currently in the "long" days in GBR time... so as we get to summer, your light cycle will shrink.... The difference between winter and summer at GBR though is only 2hours... not as big as here in the US :)
Anyway, here's your code, verified in Arduino. I added comments as well for what I added and why.
Let me know if you have any questions and I can explain further.
Lee
// We declare this here so we can use it in multiple functions
SunLocation sl;
// Since we only need to set OffSet once, then it can go in setup()
// Great Barrier reef is currently +15 hours from us.
// Current GBR Rise/Set is 4:56am/6:47am
// Instead of subtracing the 15 hours, I only subtracted 13.
// This will make it close to your 7am-9pm light cycle.
sl.SetOffset(-13,472,-13,506); // The 472/506 were corrections I made to the formula, you can leave them or set them to 0 if you want.
  // Each day we're going to update Sunrise/Sunset, so it's part of the loop() function
  // We've replaced the 7,0,21,0 with the Rise/Set Hour/Minute. Current GBR Rise/Set is 4:56am/6:47am
  DaylightPWMValue=PWMParabola(sl.GetRiseHour(),sl.GetRiseMinute(),sl.GetSetHour(),sl.GetSetMinute(),12,100,12);
  // We've replaced the 8,0,20,0 with the Rise/Set Hour/Minute +1/-1 to from GBR Rise/Set
  ActinicPWMValue=PWMParabola(sl.GetRiseHour()+1,sl.GetRiseMinute(),sl.GetSetHour()-1,sl.GetSetMinute(),12,80,12) ;
  CheckCloud();
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
int x=0;
int x=0;
cstart*=60;
cend*=60;
jedimasterben
lnevo wrote:Well, you have a lot of "lights"...Algae Scrubber and Fuge light...I didn't mess with those at all, but hopefully you can see how to adjust those if you want them based on the functions from SunLocation... if not, let me know I can help you there as well.
Lee
SunLocation sl;
  CheckCloud();
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
int x=0;
int x=0;
cstart*=60;
cend*=60;
Oh! lol. Just the main lights. They're actually controlled solely via PWM, so I'm not even putting them on a relay at this point. And I had gotten the daylight/actinics mixed up lol. No biggie, when I hook it all up tomorrow I'll just swap the two PWM ports physically. I've actually got four channels, but I keep violet and royal blue one the same time and percentage, and the neutral white and deep red/cyan/cool blue together, so technically I can do with just two channels.
And does this need the Wifi module to function properly, or is the coding built into the library I moved over?
Thanks for all your help, I appreciate it very much!
jedimasterben
Well, I went to upload the code and it says that it is too large - 39,142 bytes of 32,256 maximum. :(
EDIT: I tried also removing all the // comments in the sketch and it still says it's too big. :(
EDIT 2: Didn't realize the default sketch would be 27,790 bytes.
Comments do not take up space when compiled.
Unfortunately, it seems this feature may be too much for the plain RA. There may be some things Roberto can point you in to free up space on the RA. I know things like the time and date menu chew up a lot of space...
You could also consider getting the plus upgrade. There is a good chance we can get it squeezed in though, but I would worry about future upgrades.
Lee
jedimasterben
lnevo wrote:Comments do not take up space when compiled.
Lee
Even just doing the sketch that Roberto posted with storms (not even with the sunrise/set) was way too big. :(
Well, looks like instead of the wifi module I'll be getting the upgraded board.
I would remove the StandardMenu and switch to the Simple Menu. The Standard Menu takes up a lot of space. If you "must" have some of those features, then creating a custom menu would be the next best option for you. If you have to do some configurations, then I would simplify your main code and then do your configurations and lastly load up the simple menu.
jedimasterben
binder wrote:I would remove the StandardMenu and switch to the Simple Menu. The Standard Menu takes up a lot of space. If you "must" have some of those features, then creating a custom menu would be the next best option for you. If you have to do some configurations, then I would simplify your main code and then do your configurations and lastly load up the simple menu.
Frankly, I don't even know where to start with that. :(
Remove this line:
jedimasterben
rimai wrote:Remove this line:
lol, I swear I looked for anything 'Standard menu'. I removed that and it's down to 33,930 bytes, so still a fuzz too big!
If you remove the line to connect to the portal, it will drop the code to 27,378. You don't need this since you don't have the wifi yet (unless you are using the Windows Client to update the profile). But at least for now you can get the module up and working :)
ReefAngel.portal("jedimasterben");
jedimasterben wrote: Oh! lol. Just the main lights. They're actually controlled solely via PWM, so I'm not even putting them on a relay at this point. And I had gotten the daylight/actinics mixed up lol. No biggie, when I hook it all up tomorrow I'll just swap the two PWM ports physically. I've actually got four channels, but I keep violet and royal blue one the same time and percentage, and the neutral white and deep red/cyan/cool blue together, so technically I can do with just two channels.
You should be ok without the wifi plugged in even if it's in the code. The last post though I had you remove the line that connects to the portal, so the portal will not be updated, but when you do get the wifi you should still be able to control it remotely and even use the portal, but you won't have history or alerts until you free up more memory or upgrade the controller or remove clouds or sunrise/sunset. A few ways to go...
As far as swapping ports, if you do flip the ports you may want to change the variable names or the settings for which one comes on first :) to reflect the change.
