ReefAngel AddCustomColor question
psyrob
Post by psyrob »
It's been a while since I updated my libraries, just uploaded 1.0.2...and in the change log I saw that custom colors is re-enabled? where in your code do you add ReefAngel.AddCustomColors()? Or is just automatic when I upload the new libraries?
psyrob
Re: ReefAngel AddCustomColor question
Post by psyrob »
The reason I ask this is I uploaded the new libraries, but I can't get my outletcirclebox to display on the screen with the colors I set for outlet on and off in CustomColors....it stays on the default colors even tho I changed them in the custom colors
You should be able to add the ReefAngel.AddCustomColors() in the setup() function and it will get included. The same goes for the AddWifi (or whatever it is called).
psyrob
Post by psyrob »
Thanks Curt...that did the trick... :)
