It's been a while since I updated my libraries, just uploaded 1.0.2...and in the change log I saw that custom colors is re-enabled? where in your code do you add ReefAngel.AddCustomColors()? Or is just automatic when I upload the new libraries?
ReefAngel AddCustomColor question
psyrob
Re: ReefAngel AddCustomColor question
The reason I ask this is I uploaded the new libraries, but I can't get my outletcirclebox to display on the screen with the colors I set for outlet on and off in CustomColors....it stays on the default colors even tho I changed them in the custom colors
- Contact:
You should be able to add the ReefAngel.AddCustomColors() in the setup() function and it will get included. The same goes for the AddWifi (or whatever it is called).
psyrob
