Expansion hub with Relay expansion problems
kahlif
Post by kahlif »
So we were hooking up my RA+ that I bought a while back and I am having an issue.
I have the RA plugged into the Relay box, then USB to the expansion hub, then USB to the relay expansion module, then serial to the 2nd Relay box. I believe that is how it is all wired.
On the RA LCD, I see the 2nd Relay, and it says port 1 (Kessil) is on, but it doesn't actually power on. As far as I see, none of the ports come on. I left the relay expansion set to all 3 switches off, which should be #1. Was that right?
Any idea?
My code is here:
    ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
    ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.WaterChangePortsE[0] = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port8Bit;
    ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit;
    ReefAngel.Relay.On( Port7 );
  ReefAngel.Relay.On(Port5);
  ReefAngel.Relay.On(Port6);
  ReefAngel.Relay.On(Box1_Port5);
  ReefAngel.Relay.On(Box1_Port6);
    ReefAngel.StandardLights( Port1,11,0,19,0 );
    ReefAngel.StandardLights( Port2,19,0,11,0 );
    ReefAngel.StandardHeater( Port8,770,790 );
    ReefAngel.StandardLights( Box1_Port1,11,0,19,0 );
    ReefAngel.StandardATO( Box1_Port3,60 );
// Actinic lights - BEGIN
  // Sunrise
  ReefAngel.StandardLights(Box1_Port2,8,0,9,30);
  //Sunset
  ReefAngel.StandardLights(Box1_Port2,18,30,20,0);
  // 15min interval
  ReefAngel.StandardLights(Box1_Port2,10,15,10,30);
  ReefAngel.StandardLights(Box1_Port2,11,30,11,45);
  ReefAngel.StandardLights(Box1_Port2,13,0,13,15);
  ReefAngel.StandardLights(Box1_Port2,14,15,14,30);
  ReefAngel.StandardLights(Box1_Port2,15,0,15,15);
  ReefAngel.StandardLights(Box1_Port2,16,15,16,30);
  ReefAngel.StandardLights(Box1_Port2,17,15,17,30);
// Actinic lights - END
    ReefAngel.Portal( "kahlif" );
    int x,y;
    // Parameters
    // Main Relay Box
    // Relay Expansion
    // Date and Time
Re: Expansion hub with Relay expansion problems
How long ago was it?
Can you check if you have all 3 jumpers plugged in on your head unit?
kahlif
Post by kahlif »
Bought it in September (I am the one getting the new LCD screen that Jess showed you).
I need to look at the jumpers. Are those in a manual somewhere? I don't think I saw that...
kahlif
Post by kahlif »
Here is a shot of the board...
Ok, the jumpers are there.
So, upload the attached ino code to RA.
Then, open Serial monitor on menu Tools->Serial Monitor.
Make sure you have 57600 baud selected.
If you don't see anything in the window, reboot RA.
Copy and paste what you get in the Serial monitor.
I2CScanner.ino
(1.88 KiB) Downloaded 504 times
kahlif
Post by kahlif »
I2CScanner ready!
starting scanning of I2C bus from 1 to 128...
addr: 1 addr: 2 addr: 3 addr: 4
addr: 5 addr: 6 addr: 7 addr: 8
addr: 9 addr: A addr: B addr: C
addr: D addr: E addr: F addr: 10
addr: 11 addr: 12 addr: 13 addr: 14
addr: 15 addr: 16 addr: 17 addr: 18
addr: 19 addr: 1A addr: 1B addr: 1C
addr: 1D addr: 1E addr: 1F addr: 20 found!
addr: 21 addr: 22 addr: 23 addr: 24
addr: 25 addr: 26 addr: 27 addr: 28
addr: 29 addr: 2A addr: 2B addr: 2C
addr: 2D addr: 2E addr: 2F addr: 30
addr: 31 addr: 32 addr: 33 addr: 34
addr: 35 addr: 36 addr: 37 addr: 38
addr: 39 addr: 3A addr: 3B addr: 3C
addr: 3D addr: 3E addr: 3F addr: 40
addr: 41 addr: 42 addr: 43 addr: 44
addr: 45 addr: 46 addr: 47 addr: 48
addr: 49 addr: 4A addr: 4B addr: 4C
addr: 4D addr: 4E addr: 4F addr: 50 found!
addr: 51 addr: 52 addr: 53 addr: 54 found!
addr: 55 addr: 56 addr: 57 addr: 58
addr: 59 addr: 5A addr: 5B addr: 5C
addr: 5D addr: 5E addr: 5F addr: 60
addr: 61 addr: 62 addr: 63 addr: 64
addr: 65 addr: 66 addr: 67 addr: 68 found!
addr: 69 addr: 6A addr: 6B addr: 6C
addr: 6D addr: 6E addr: 6F addr: 70
addr: 71 addr: 72 addr: 73 addr: 74
addr: 75 addr: 76 addr: 77 addr: 78
addr: 79 addr: 7A addr: 7B addr: 7C
addr: 7D addr: 7E addr: 7F addr: 80
done
The controller is not seeing the module.
The address of the #1 expansion module is 38.
Can you try the same thing without the hub?
kahlif
Post by kahlif »
Jeez, basic troubleshooting....
As soon as I plugged the USB from the Relay Expansion module into the main relay, everything turned on...
The expansion hub is not working then....
One question, is there a power supply needed for it? I see an AC adapter port, but it didn't come with one...
Humm..
Maybe you got one of the older models that required AC adapter.
I'll send you the correct one with the other item.
kahlif
Post by kahlif »
So I got the replacement...
Interestingly, now with the new hub, I see the LED display (which works now!) with 16 ports, and the right ports are on, but the second relay box is not actually turning ports on.
What else can it be?
So, is it still doing the same thing?
kahlif
Post by kahlif »
Yes. The ports say they are on, but nothing comes on. If I connect it directly, it works.
kahlif
Post by kahlif »
Interestingly, the water level expansion, connected through the hub, works perfectly...
I2CScanner ready!
addr: 4D       	addr: 4E       	addr: 4F found!	addr: 50 found!
done
Weird.
Yes, 4F is the water level module.
Can you try swapping cables?
You mentioned that you got the controller to see the relay expansion by plugging it in directly to the relay box, right?
Does it show address 38 found and box works like it should?
kahlif
Post by kahlif »
When you say swap cables, which do you mean? I bought new USB cables, and tried all the combos of them. I also tried those cables on a digital camera to validate functionality.
I tried swapping the serial cables, but no change.
Yes, if I plug the relay expansion directly to the main relay box, 38 is found and ports function as normal...
kahlif
Post by kahlif »
Guess what!
I figured out what was wrong...
The reason this was weird, is because the issue is intermittent. The USB port on the Relay Expansion box seems to be loose, so wiggling the USB cable turns it on.
It is working now!
rossbryant1956
Post by rossbryant1956 »
are these memory locations (38, 3C, etc.) and a map of what should be expected if we are looking for something. Thz
Yes, address 38 is the first relay box.
It goes from 38 to 3f for the eight possible expansion boxes.
rossbryant1956
so 38
In your other thread you posted you had address 3C found.
What happened to it?
