I have the RA plugged into the Relay box, then USB to the expansion hub, then USB to the relay expansion module, then serial to the 2nd Relay box. I believe that is how it is all wired.
On the RA LCD, I see the 2nd Relay, and it says port 1 (Kessil) is on, but it doesn't actually power on. As far as I see, none of the ports come on. I left the relay expansion set to all 3 switches off, which should be #1. Was that right?
Any idea?
My code is here:
ReefAngel.FeedingModePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.Relay.On(Box1_Port5);
ReefAngel.Relay.On(Box1_Port6);
ReefAngel.StandardLights( Port1,11,0,19,0 );
ReefAngel.StandardLights( Port2,19,0,11,0 );
ReefAngel.StandardHeater( Port8,770,790 );
ReefAngel.StandardLights( Box1_Port1,11,0,19,0 );
ReefAngel.StandardATO( Box1_Port3,60 );
// Actinic lights - BEGIN
// Sunrise
ReefAngel.StandardLights(Box1_Port2,8,0,9,30);
//Sunset
ReefAngel.StandardLights(Box1_Port2,18,30,20,0);
// 15min interval
ReefAngel.StandardLights(Box1_Port2,10,15,10,30);
ReefAngel.StandardLights(Box1_Port2,11,30,11,45);
ReefAngel.StandardLights(Box1_Port2,13,0,13,15);
ReefAngel.StandardLights(Box1_Port2,14,15,14,30);
ReefAngel.StandardLights(Box1_Port2,15,0,15,15);
ReefAngel.StandardLights(Box1_Port2,16,15,16,30);
ReefAngel.StandardLights(Box1_Port2,17,15,17,30);
// Actinic lights - END
ReefAngel.Portal( "kahlif" );
int x,y;
// Parameters
// Main Relay Box
// Relay Expansion
// Date and Time
