portal problems?
Re: portal problems?
what version of the dev libraries are you running?
Maybe this will help', it actually started (the problem with memory) when I downloaded the new ini file as advised by Roberto.
PostPosted: Sat Jan 19, 2013 5:54 pm
I wonder if you need to apply the ini file in this post:
viewtopic.php?p=16602#p16602
Dave,
Thank you very much for looking into this. I will test on my system shortly.
Mike
Mike
75G with 30G sump | 52 LED - RapidLED Lighting (DIY) |
ReefAngel for Meanwell ELN-D Drivers | Reef Octopus HOB-1000
Way to much time and money invested.....
Sorry it took so long, was building a new computer for Client use.
The new client fixed all my issues. Portal and memory page are now working.
Thank you very much.
Mike
Mike
