Anyone know the pin out from USB to 9 pin serial ? or at least the pins out of the RA to 9 pin serial ?
I want to connect to the RA though a 9 pin serial port instad of a USB port, if you could not tell from above.
MIke
RA to 9 pin serial pin out ?
75G with 30G sump | 52 LED - RapidLED Lighting (DIY) |
ReefAngel for Meanwell ELN-D Drivers | Reef Octopus HOB-1000
Way to much time and money invested.....
Re: RA to 9 pin serial pin out ?
Thanks Roberto -
I guess it will not be quite as easy as I had hoped ...
RX
TX
GND
RX
TX
GND
