I have an RA that I setup about two weeks ago. All was working great and the PH probe was reading correctly in my tank.
I decided to setup the Client software to start uploading to the portal. Again, all was going well and I was watching my PC screen with all my data on it.
Then the next day I noticed that my PH was reading about 2 or lower. Robert and I did a bunch of troubleshooting as I thought I had a bad probe. If I took probe and put in it testing solution it read correctly (7 or 10). In my tank 2.
Robert had me put the probe in a cup of tank water, it read correctly. Robert told me a I had a voltage leak in my tank. I checked everything and nothing really made any difference. I tested with a multimeter and it shows .021 volts ( basically nothing).
Then I stated to think about when this bad reading stated to happen, it was when I hooked up the computer.
I disconnected the USB-TTL cable from the computer. Bam - the PH readings returned to normal. Plugged the cable back in and the PH dropped to 2.
We found it right, a bad computer and somehow had screwed up USB ports.
I loaded a totally different PC - same problem - USB port does not matter, tried them all.
I don't understand how the power in the USB could be affecting the PH probe ?
Has anyone else seen something like this ? Anyone have something to try ?
Sorry for the long winded post.
Mike
