it is a reef angel plus
I am operating a mac on OSX 10.6.8
So far I have the reef angel hardware set up and seemingly working fine.
Most things uploaded onto mac however I cant get the wifi utility to upload from the sight.
I have a small wifi box but there is no press to connect button on the unit so I will have to go the long way.
Before that though, I cant seem to get the RA to speak to the computer. I have the ttl to usb fitted correctly, have uploaded the drivers, powered down and powered up.
I have settings on tools on:
Board: reef angel plus
serial port dev.tty usb serial
but when I go to file:sketch book or file:examples i get no drop down options.
I hit upload anyway and get an error.the error reads: ( last couple of lines):
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:5: undefined reference to `setup'
/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino/main.cpp:15: undefined reference to `loop'.
SOOOO first things first help me gte it plugged into the computer, then we can work on wifi
i should add that the unit doesn't power up with just the usb ttl connection ( not sure if it should), so I have it plugged into the relay box for power ( have tried both ways)
