This is a bug or relay problem?
Relay problem...
baroutas
- Contact:
Relay problem...
Hi! In my relay box, Port 4 (Standar lignhts) does not Work. The RA controler show me '' the Port is open'', but the lights does not open. Until now I have never use the port 4. When i put the lights to an other open Port, the lights Open.
baroutas
- Contact:
Re: Relay problem...
Also when i open and close the port 4 i can not hear the typical Clik that the relay does when open and close one Port.
This is my code:
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 350 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,278,280 );
ReefAngel.StandardFan( Port2,310,320 );
ReefAngel.StandardLights( Port3,13,50,22,0 );
ReefAngel.StandardLights( Port4,15,30,19,0 );
ReefAngel.DosingPumpRepeat( Port5,0,1240,10 );
ReefAngel.StandardLights( Port6,20,30,23,59 );
ReefAngel.PWM.SetDaylight( PWMSlope(14,0,21,0,10,100,15,10) );
ReefAngel.PWM.SetActinic( PWMParabola(20,0,23,59,0,100,0) );
ReefAngel.Portal( "xxxxxxxx" );
This is my code:
If it's a bad port you'll need to verify using the Relay Box test software. Roberto can advise after that on RMA or other appropriate steps. Your code looks ok...
baroutas
- Contact:
How can i verify the relay box? what are the steps and conections? Sory to asking so mutch....
- DrewPalmer04
Sketch-> examples->relay test?
baroutas
- Contact:
Ok i make the test and show me the prot 4 OPEN but the port does not open.... All the ather ports is Ok! Is anything i can do??
baroutas
- Contact:
- DrewPalmer04
DrewPalmer04 wrote:Sketch-> examples->relay test?
Sorry. Tried my best off memory
- DrewPalmer04
baroutas wrote:What is mean RMA?
Return merchandise authorization
baroutas
- Contact:
00Warpig00
Could the VGA cable be missing a single connection?
Nick
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
baroutas
- Contact:
I don't think show. I try to change the power relay (no 4) inside the main relay and if is not work then we will see!!!! Now i am in the midle of this work and i waet the spare part.....
baroutas
- Contact:
Ok!!! I replace the power relay iside main relay (with roberto instractions) and everythink works perfect!!It is very simle Think!!! Thanks Roberto!!
baroutas
- Contact:
Hi! Today new problem With relay box....!
1. Stop working the relay 4. when i give them the order to open and close that does not responding!!
2. When open and close relay 2, open and close relay 4 and 6 All together!!!
3. When open and close relay 6, open and close relay 2 and 4 all together!!!
4. Also When i give an order to relay 2 and after i give an order to relay 6 that does not respond and the opposite! The relay 4 still responding only when i give an order to the ather two relays!
Bug or damange from replaced relay?? Yesterday everethink works good
That looks like your svga cable is shorted out.
I think it could even be the initial problem.
If you move the cable around, does it change anything?
baroutas
- Contact:
I change the cable with a new one and everethink works perfect!!! Agains one THANKS!!
00Warpig00
baroutas
- Contact:
