Need help coding WM
Ask in here.
treetopflyn
Need help coding WM
Post by treetopflyn »
Below is my current code. Starting at 7:00am I would like one of the Make Maker outlets to stay on for 3.5 hours while the other one switches on and off randomly. Every 3.5 hours I would like them to switch ending at 9pm.
Thanks in advance
boolean OverrideWM=false;
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 889 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Timer[1].SetInterval(600);
if (hour()>=21 || hour()<7)
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port6);
ReefAngel.WavemakerRandom1( Port5,30,90 );
ReefAngel.WavemakerRandom2( Port6,30,90 );
ReefAngel.Relay.DelayedOn( Port7,0 );
ReefAngel.Timer[1].Start();
OverrideWM=true;
if (ReefAngel.Timer[1].IsTriggered())
OverrideWM=false;
if (OverrideWM)
ReefAngel.Portal( "treetopflyn" );
int x,y;
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,54, ReefAngel.Params.PHExp );
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
Re: Need help coding WM
Try this:
      // ReefAngel.WavemakerRandom1( Port5,30,90 );
      // ReefAngel.WavemakerRandom2( Port6,30,90 );
      if (elapsedSecsToday(now())%25200<12600)
    OverrideWM=true;
    OverrideWM=false;
  if (OverrideWM)
  int x,y;
  // pH Expansion
  // Relay Expansion
