New User, PH and SAL doesnt work!
kraken
Post by kraken »
Hi, I got the RA advanced with the wifi and SAL expansion kit, however, I couldnt get the ph and sal to work.
Please help, thanks
ReefAngel.UseFlexiblePhCalibration();,
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.PHMin=550;// 550=PH7.0
ReefAngel.PHMax=830;// 830=PH10.0
ReefAngel.DayLights( Port1 );
ReefAngel.Portal( "kraken" );
int x,y;
// Parameters
// Salinity
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
// Main Relay Box
// Date and Time
Re: New User, PH and SAL doesnt work!
Can you explain better what is happening?
kraken
Post by kraken »
Never mind, silly me, I got the probes mixed up, now both working.
However, would you advice how to change the salinity value to relative gravity instead?
Also the salinity is being displayed as 350pt on the main controller display instead of 35pt.
Thanks.
You will need to come up with your own conversion table.
This is for reference: http://www.reefs.org/library/salinity.html
Just make sure it is temperature compensated too.
It changes as temperature goes up and down.
kraken
Post by kraken »
Grazie Roberto, will try to figure it out
