Hi Guys I have a single relay box set up at this stage, but it seems ports 5 and 6 are linked some how, when one is turned on the other also switches on , although it doesnt show up on the screen as such, same for turning off.
Any thoughts?
rekays linked
fatman
Re: rekays linked
If I remember correctly those are the two that have the heavy duty relays for the wavemaker. Is there a chance that you have enabled the wave maker in your code?
aus996
Re: rekays linked
Quite possible, Iwill chekc when I get home, i did seem to recall these two ports were different to the rest cheers
