Not sure how this Apogee PAR meter hooks in?
Not Sure if I have an analogue or PWM unit? Is there any way to tell?
more questions and pictures coming in next post... damn limits and no photobucket...
Several Questions, new to reef angel
- cody.sheridan-2008
Cheers
Cody
Cody
Re: Several Questions, new to reef angel
Worth noting I got the unit 2nd hand but new.
I got two probes with it.
I presume this is a PH probe, but the other one definitely is too. Will the other probe also work?
Cheers
Cody
Cody
fatman
Not sure on the PAR meter, but you likely have a PWM controller. The analog ones have a sticker on the relay box that says analog. You will only be able to run one pH probe without an expansion module.
Cheers, bugger was hoping for analog as I already have some drivers for it.fatman wrote:Not sure on the PAR meter, but you likely have a PWM controller. The analog ones have a sticker on the relay box that says analog. You will only be able to run one pH probe without an expansion module.
Cheers
Cody
Cody
