I use the water level expansion - works great.
I would like to use the two float switches as follows:
Low Switch: Put in my ATO bucket to indicate if the bucket is low.
High Switch: Additional fail safe for the water level - put it in my sump to turn the ATO pump relay off if the sump gets to a certain level (this would also indicate if my return pump malfunctions for some reason as the water in the display will flow to the sump)
Where can I find the code for this?
ATO Float switch
Re: ATO Float switch
You can use something like this:
ReefAngel.Relay.Off(Port1);
ReefAngel.Relay.Off(Port8);
ReefAngel.WaterLevelATO(Port1,60,70,75);
ReefAngel.Relay.On(Port8);
