Request for RA wizard functionality.
I have used the Wizard to generate code and seen others do the same. Many including myself also have custom code pasted into the areas in the generated code after generation (between the put your code here tags) to add customizations. Would it be possible to set up the Wizard to save all the user's custom code pasted into these areas and have it included in those same areas in newly generated code? a "Custom Code" screen during the wizard that reads a file that saves\contains allows you to read in\type in your custom code for inclusion when building your code for upload.
Nick
00Warpig00
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
00Warpig00
Re: Request for RA wizard functionality.
oops accidentally put this under the hardware requests. meant to have it down in the software requests area.
Nick
Nick
180G FOWLR
20GH QT#1
29G QT#2
20GH QT#1
29G QT#2
It's been logged:
https://github.com/reefangel/Wizard/issues/9
I have one...
If you had a page in the wizard to ask users to define their ports and setup a #define section to label their ports. Even if you didn't use it in the code it would help people reading that code to understand the code that users post..but if you could use those defined it would make wizard generated code easier to read for all...
00Warpig00
