Also i want to change the port 6 (wavemaker pump) to Chiler - Funs. How can i do that?
![Question :?:](./images/smilies/icon_question.gif)
lenovo witch pair of cable, from mean well driver, (red- black or wite-blue) will go to the pwm ports on the relay box? I think i have put the wrong pair to the pwm ports and the port just open and close the led with no diming.......lnevo wrote:Baroutas...the driver you buy will have 6 cables comin out of it..one pair is +/- for your led string. The second pair is for 120/220 volt input and the last pair will be for the dimming port. That pair will go to the pwm ports on the relay box.
This means that the blue-white pair of cable goes to the PWM port???lnevo wrote:Blue is dim+ white is dim -
