Adding ATO to developmental PDE
Re: Adding ATO to developmental PDE
It was on dev libs, but I think it could be unreleased yet.
If you use the update utility, you will get the latest code even if it was not released.
http://forum.reefangel.com/viewtopic.php?f=8&t=2
Give it a shot.
I'll try it over here too.
serhiyi
Post by serhiyi »
Thank you. This is a very nice tool.
I reinstalled all libs from scratch.
Loaded code. It looks like wifi is not going crazy now.
Trying to figure out emails. I triggered ATO Hight several times with no email. Then I was playing with ATO Low for couple of seconds and triggered ATO High again. This time I got email.
Not sure if it was delay or somehting else. Will play with it a little more.
Thank you for your help.
serhiyi
Post by serhiyi »
Ok. Getting better but still can't figure out.
After new code using new libs installed I did not get email. I cleared ATO on controller.
Triggered ATO three times and got 2 emails.
Cleared ATO. Triggered ATO 3 times, got only one email.
Cleared ATO. Triggered ATO 4 times, only 3 emails.
To clarify, I checked email after each trigger and set new trigger only after getting email.
After writing this post I triggered ATO again and got email.
Looks like there is timeout somewhere that stops sending emails.
Just want to confirm if this is the case.
Thanks for your help, Roberto. It saved me a lot of hair :)
