display of temp settings
aus996
Post by aus996 »
Just adding to the wishlist, but i often find myself wondering what I set my high and low temp and overheat to. yes yes, i have them written down ( somewhere) but just thought it would be cool if you could see the settings in small italics when you look at the dashboard through the portal. Just a thought
Sebyte
Re: display of temp settings
Post by Sebyte »
Why not just look at the internal memory settings page of the portal? Unless you have hard coded them, which is not the best option.
Internal memory is the way to go! Hard coded is good and simple when your starting out...
Your other option is to display them on the screen...
