WIFI Issue
Rey
WIFI Issue
Post by Rey »
I am having trouble detecting my WIFI on Tera Term VI using serial port connection.
Also when I follow the instruction from Wifi Attachment Manual v1.3 to load the code below to my Controller. I get 10.1.10.120 IP when I connect the wifi to my controller.
#include <EEPROM.h>
#include <NokiaLCD.h>
If your network uses WEP authentication, please change the following defines:
WLAN_AUTH MODE
WLAN_WEP_KEY
WLAN_WEP_NUM
WLAN_SSID
If your network uses WPA1 or WPA2 authentication, please change the following defines:
WLAN_AUTH MODE
WLAN_WLAN_PHRASE
WLAN_SSID
WLAN_AUTH MODE
Wireless Authentication Mode
0 Open (Default)
1 WEP-128
2 WPA1
3 Mixed WPA1 & WPA2-PSK
4 WPA2-PSK
5 Not Used
6 Adhoc, Join any Adhoc network
#define WLAN_AUTH_MODE 4  //WPA2-PSK authentication mode
WLAN_WEP_KEY
Wireless WEP Key for WEP-128 authentication mode
#define WLAN_WEP_KEY "112233445566778899AABBCCDD"  //WEP-128 key - change if using WEP-128 authentication mode
WLAN_WEP_NUM
Wireless WEP Key to be used for WEP-128 authentication mode
#define WLAN_WEP_NUM 1  //WEP-128 key to be used - change if using WEP-128 authentication mode
WLAN_PHRASE
Wireless Passphrase for WPA1 or WPA2 authentication mode
#define WLAN_PHRASE "testing"  //WPA1 or WPA2 pass phrase - change if using WPA1 or WPA2 authentication mode
WLAN_SSID
Wireless SSID to associate with
#define WLAN_SSID "testing"  //change to your SSID
  int waitbutton=false;
  int status=false;
  char conn[5];
  int connindex=0;
  char ip[17];
  int ipindex=0;
  unsigned long lastmillis;
  ReefAngel.Init();  // Initialize
  ReefAngel.LCD.Clear(255,0,0,131,131);  // Clear screen
  ReefAngel.LCD.DrawText(0xE0, 255, 40, 5,"Wifi Setup");  // Draw text
  ReefAngel.LCD.DrawText(0xE0, 255, 25, 45,"Press Joystick");  // Draw text
  ReefAngel.LCD.DrawText(0xE0, 255, 32, 65,"to continue");  // Draw text
  ReefAngel.LCD.Clear(0,0,15,131,15);  // Clear screen
  do
    if (ReefAngel.Joystick.IsButtonPressed()) waitbutton=true;
  while (!waitbutton);
  ReefAngel.LCD.Clear(255,0,16,131,131);  // Clear screen
  delay(1000);
  Serial.end();
  delay(100);
  Serial.begin(9600);
  delay(100);
  Serial.println("exit");  // exit setup mode
  delay(100);  //  wait .1 sec
  Serial.flush();   // Flush incoming serial
  Serial.print("$$$");  // enter setup mode
  delay(300);  //  wait .3 sec
  Serial.println("set u b 57600");  // set baud 57600
  Serial.println("save");
//    Serial.print("join ");
//    Serial.println(WLAN_SSID);
//    delay(750);  //  wait 1 sec
//    Serial.flush();   // Flush incoming serial
  Serial.println("reboot");
  delay(500);  //  wait .5 sec
  Serial.end();
  delay(100);
  Serial.begin(57600);
  delay(100);
  setupwifistart:
  Serial.println("show c");  // request connection status
  lastmillis=millis();
  do  // flush serial until get 8, which is always constant on the connection status value.
    if (Serial.available()>0) conn[0] = Serial.read();
    if (conn[0] == '8')
      connindex++;
      status=true;
    if (millis()-lastmillis>2000) goto setupwifistart;
  while (!status);
  status=false;
  do  // Acquire 4 bytes of data representing the connection status
    if (Serial.available()>0) conn[connindex++] = Serial.read();
    if (connindex > 3)
      conn[4]=0;
      ReefAngel.LCD.DrawText(0, 255, 10, 25,"Status:");  // Draw text
      ReefAngel.LCD.DrawText(0, 255, 90, 25,conn);  // Draw text
      status=true;
  while (!status);
  if (conn[2]=='3')  // check if wifi attachment is already setup
    ReefAngel.LCD.DrawText(0, 255, 10, 35,"Already Setup");  // Draw text
    ReefAngel.LCD.DrawText(0, 255, 10, 45,"Exiting...");  // Draw text
    if (WLAN_AUTH_MODE==1)
      //ReefAngel.LCD.DrawText(0, 255, 10, 35,"set wlan key ");  // Draw text
      //ReefAngel.LCD.DrawText(0, 255, 90, 35,WLAN_WEP_KEY);  // Draw text
      Serial.print("set w k "); // set wlan wep key
      Serial.println(WLAN_WEP_KEY);
      delay(1000);  //  wait 1 sec
      //ReefAngel.LCD.DrawText(0, 255, 10, 45,"set wlan num ");  // Draw text
      //ReefAngel.LCD.DrawText(0, 255, 90, 45,WLAN_WEP_NUM);  // Draw text
      Serial.print("set w n "); // set wlan wep key number
      Serial.println(WLAN_WEP_NUM);
    if (WLAN_AUTH_MODE==2 || WLAN_AUTH_MODE==3 || WLAN_AUTH_MODE==4)
      //ReefAngel.LCD.DrawText(0, 255, 10, 35,"set wlan phrase ");  // Draw text
      //ReefAngel.LCD.DrawText(0, 255, 10, 45,WLAN_PHRASE);  // Draw text
      Serial.print("set w p "); // set wlan passphrase for WAP1/WAP2
      Serial.println(WLAN_PHRASE);
    //ReefAngel.LCD.DrawText(0, 255, 10, 55,"set wlan ssid ");  // Draw text
    //ReefAngel.LCD.DrawText(0, 255, 10, 65,WLAN_SSID);  // Draw text
    Serial.print("set w s "); // set wlan ssid
    //ReefAngel.LCD.DrawText(0, 255, 10, 75,"set ip localport 80");  // Draw text
    Serial.println("set i l 2000");  // set ip port
    //ReefAngel.LCD.DrawText(0, 255, 10, 85,"set comm close 0");  // Draw text
    Serial.println("set c c 0");  // set comm close to nothing
    //ReefAngel.LCD.DrawText(0, 255, 10, 95,"set comm open 0");  // Draw text
    Serial.println("set c o 0");  // set comm open to nothing
    //ReefAngel.LCD.DrawText(0, 255, 10, 105,"set comm remote 0");  // Draw text
    Serial.println("set c r 0");  // set comm remote to nothing
    Serial.println("set c i 3");  // set comm idle to 3
    Serial.println("set c s 2048");  // set comm IP packet size to 2048
    Serial.println("set s p 0");  // set system printlvl 0
//    ReefAngel.LCD.DrawText(0, 255, 10, 75,"set wlan channel 0");  // Draw text
//    Serial.println("set wlan channel 0");  // set scan channel
//    ReefAngel.LCD.DrawText(0, 255, 10, 85,"set wlan join 1");  // Draw text
//    Serial.println("set wlan join 1");
//    ReefAngel.LCD.DrawText(0, 255, 10, 95,"set wlan auth ");  // Draw text
//    //ReefAngel.LCD.DrawText(0, 255, 60, 95, WLAN_AUTH_MODE);  // Draw text
//    Serial.print("set wlan auth ");
//    Serial.println(WLAN_AUTH_MODE);
  getipstart:
  Serial.println("get ip");  // request connection status
  for (int a=0; a<2; a++)
    status=false;
      if (conn[0] == 'I')
        connindex++;
        status=true;
      if (millis()-lastmillis>2000) goto getipstart;
    while (!status);
  for (int a=0; a<2; a++) if (Serial.available()>0) conn[0] = Serial.read();
  status=false;
    if (Serial.available()>0) ip[ipindex++] = Serial.read();
    if (ip[ipindex - 1] == '\r')
      ip[--ipindex]=0;
      ReefAngel.LCD.DrawText(0, 255, 10, 115,ip);  // Draw text
      status=true;
    if (ipindex > 16) ipindex=16;
  while (!status);
  endline:
  delay(100);
Re: WIFI Issue
You are all set with the wifi setup if you are getting the ip address.
Regarding the Tera Term, make sure to use baud 57600.
9600 baud is only for when you get it for the first time or you did factory reset.
Rey
Re: WIFI Issue
Post by Rey »
but the 10.1.10.120 is not my home network IP Subnet. How do I change the IP to what I want? BTW, thank you for the cable I received it today.
Re: WIFI Issue
Oh, so maybe it is reminescent of old settings.
Make sure to change the WLAN_PHRASE and WLAN_SSID to your own wifi, on the code you posted above.
Is your router setup to WPA2-PSK authentication?
Rey
Re: WIFI Issue
Post by Rey »
I changed the WLAN_PHRASE and WLAN_SSID to what my WPA2-PSK is using, but I still get the 10.1.10.120:2000 on the controller screen when I connect the wifi to it.
Re: WIFI Issue
Try doing factory reset and start from scratch
Rey
Re: WIFI Issue
Post by Rey »
I did a factory reset on the wifi and re-did all the steps. Now the IP is 0.0.0.0:2000
Re: WIFI Issue
It is not picking up the ip address.
Something is not being setup correctly.
Let's try a different way.
https://github.com/davemolton/Graphical-Wifi-Utility
Download and use the graphical utility that Dave created.
Rey
Re: WIFI Issue
Post by Rey »
Awesome!! That tool works. Thank you.
Rey
Re: WIFI Issue
Post by Rey »
Is it possible to set a Static IP instead of DHCP?
Re: WIFI Issue
In Tera Term, you can use these commands:
set ip dhcp 0
set ip address <addr>
set ip netmask <value>
set ip gateway <addr>
Try that and see if that works for you.
Rey
Re: WIFI Issue
Post by Rey »
editing this post:
I re-installed my Tera Term and I am able to connect to my wifi, but I can not type in any commands. All I see is a continuosly
GET /r99 HTTP/1.1
Host: 10.10.10.10:2000
Connection: Keep-Alive
dmolton
Re: WIFI Issue
Post by dmolton »
I was never able to send commands over wifi either. I always had to have the adapter plugged into the computer and connect over serial/usb. The wifi utility you downloaded has an advanced tab that works just like teraterm. Just type a command in the text box and press <return> to send it.. I forget the details now, but I think you start sending commands by typing $$$ and then be sure to type "save" when finished... Just another option..
Rey
Re: WIFI Issue
Post by Rey »
Both Tera Term and Dave's wifi tool works now. I forgot to type $$$ before i send a command. Thank you all.
