phone not connecting
Ademster
Post by Ademster »
since I have added expansion hub, orp, relay box, and pwm modules the phone doesn't connect.
it appears to be updating the portal and the client app. but not the phone it continues to error out.
I uninstalled the app from the phone and re-downloaded it. no change.
any ideas?
Adam
58 Gal
Re: phone not connecting
I think you need to increase the buffer on the wifi attachment.
You will need a serial terminal, like putty or tera term.
If you are using Mac, you can use coolterm.
Connect to the wifi attachment at 57600 baud.
To enter command mode, you need to type $$$
The use these commands:
set c s 1420
save
reboot
Ademster
Post by Ademster »
Where do I enter the code?
I am using windows 7
Adam
58 Gal
You need to use a serial terminal like putty or tera term
Ademster
Post by Ademster »
I downloaded tera term, not sure how to use it.
Adam
58 Gal
Check the wifi manual.
Ademster
Post by Ademster »
Alrighty then, followed all the steps. We'll see what happens.
Adam
58 Gal
Ademster
Post by Ademster »
worked perfect through the night, no errors! Thanks Roberto
Adam
58 Gal
