Can't download reef angel installer
Redadeath
I downloaded rag from website but seems I got only aurueno icon and rag icon is missing when I click it from start menue I get error missing icon any help plz I am running windows vista 32 bit
when it comes to programming i "always need help "
Redadeath
Re: Can't download reef angel installer
reef angel generator.exe
That is long gone and deprecated.
You should use the Reef Angel Wizard.
http://forum.reefangel.com/viewtopic.php?f=8&t=1297
Redadeath
does the wizard provides "watchdogtimer"
and how can i manually change dimiing lights after i install the wizard from ipad application if i need to change the ratio of lights later from my ipad
sorry for my language it is not my mother language
thank you roberto
thank you roberto
WDT is a built-in feature that is enabled on all RAs now.
Yes, you can change memory settings from ipad.
Redadeath
i coded my reef angel with the wizard and now if i need to change any values in the ipad app
it just say memory update but really nothing change
as u can see
when i try to change the metalhalide on off time and press save then close the application or go to main menue it return back to this settings
whatever i change and click save it says "memmory updated " but really nothing changes and the light on my display tank still have the same ratio
the only working thing is the main really controll
on/off relay 1
2
3
etc
as u can see
on/off relay 1
2
3
etc
Yeah i think there is a problem with the ios app...never works for me either. I just use http and go straight to the controller.
Http://reefangelwifi:2000/mi100,1
As an example mi is for int, mb would be for byte and the value after comma is what you want to set...
I know not as elegant, but a workaround...
Redadeath
i dont think this is the case "ios problem " because i downloade on both ipad and iphone
and both give the same readings
so i think it is the main unit problem
waiitng for help
thank you all
waiitng for help
thank you all
iPad and iPhone are both iOS apps....I think the function that does memory does not work on either. I've tried on both as well.
Don't use MH hours...
The wizard doesn't use those memory locations...
It uses the std lights schedule.
Redadeath
but i cannot aslo control pwm of leds
whan i canhe it to any % nothing changes
i also tries client suit : 3 and the same issue
Redadeath
InternalMemory.OverheatTemp_write( 896 );
ReefAngel.Relay.DelayedOn( Port2,5 );
ReefAngel.StandardHeater( Port3,240,250 );
ReefAngel.StandardFan( Port4,250,260 );
ReefAngel.StandardLights( Port7,14,0,20,0 );
ReefAngel.MHLights( Port8,16,0,18,0,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(14,0,20,0,15,40,15) );
ReefAngel.PWM.SetActinic( PWMParabola(14,0,20,0,50,80,50) );
ReefAngel.Portal( "redadeath" );
You need to choose internal memory path when generating your code through the wizard.
Its still not going to work from the phone...just my experience...if it does please lmk.
If it did his values in the app would have changed with no effect instead of reverting.
