Error Uploading
Lockes
Error Uploading
Post by Lockes »
Hey
Any reason why you can see why the uplioad is giving me an error
Verification works but then when it finishes the upload it says "Error uploading" in an orange notification
ReefAngel.LCD.DrawDate(6, 64);
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 19, 4 , "BOBS REEF");
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 59, 119, 59);
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, COLOR_WHITE, 33, 15, "Tank Water");
char text[7];
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, DefaultBGColor, 15, 26, text);
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, DefaultBGColor, 60, 26, text);
ReefAngel.LCD.DrawLargeText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 15, 35, "pH");
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 15, 42, text);
ReefAngel.LCD.DrawLargeText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 60, 35, "pH2");
ConvertNumToString(text, ReefAngel.Params.PHExp, 100);
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 60, 42, text);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,84,"ATO");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,94,"N/A");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,104,"CO2");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,114,"N/A");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,84,"Return");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,94,"Vortech");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,104,"N/A");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,114,"Heater");
ReefAngel.LCD.DrawCircleOutletBox(60, 86, TempRelay, true);
    InternalMemory.OverheatTemp_write( 260 );
    ReefAngel.SingleATO( true,Port2,60,0 );
    ReefAngel.StandardLights( Port3,4,0,23,0 );
    ReefAngel.StandardHeater( Port7,250,255 );
    if (ReefAngel.Params.PHExp <= 635) ReefAngel.Relay.Off(Port6);  // If probe 2 PH <= 7.35 - turn off CO2
    if (ReefAngel.Params.PHExp >= 652) ReefAngel.Relay.On(Port6);  // If probe 2 PH >= 7.52 - turn on CO2    if (ReefAngel.Params.PH <= 790) Relay.Off(Port6);  // If PH <= LowPH - turn off CO2
    if (ReefAngel.Params.PH <= 790) ReefAngel.Relay.Off(Port6);  // If probe 1 PH <= 7.90 - turn off CO2
    ReefAngel.Portal( "Lockes" );
Watchdog Timer
Version Menu
Wifi Attachment
Custom Main Screen
Extra Font - Medium Size (8x8 pixels)
PH Expansion Module
Simple Menu
Binary sketch size: 30,010 bytes (of a 32,256 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM6 -b115200 -D -Uflash:w:C:\Users\Andrew\AppData\Local\Temp\build6963156121354196331.tmp\sketch_sep16b.cpp.hex:i
avrdude: Version 6.0, compiled on Apr  6 2012 at 19:29:19
         Using Port                    : \\.\COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x64
avrdude done.  Thank you.
Error Uploading
Can you paste the full error message? What happens when you click the check mark to verify instead of upload?
Lockes
Re: Error Uploading
Post by Lockes »
Verify works fine
between the code and the upload message below is the error in orange saying "error uploading"
I will try load a screenshot as well if needed
Re: Error Uploading
Do you have RA or RA+?
Did you check the serial port and board to make sure they are set correctly?
Lockes
Re: Error Uploading
Post by Lockes »
Hey Rimai
Well this is not the first time I have uploaded and never had an issue before, but is there anything in particular I should then check?
This is standard RA
Re: Error Uploading
Let's just make sure that you have Reef Angel Controller w/ optiboot selected under Tools->Board.
Then, try any other serial ports you may have listed under Tools->Serial Port.
Also, make sure that the black wire is on the right most pin on the RA connector.
Lockes
Re: Error Uploading
Post by Lockes »
Check
Reef Angel Controller w/ optiboot selected - YES
Only allows me COM6
Compiled correctly as per blow
Error as per below
Re: Error Uploading
Does RA reboot when the message Rebooting Reef Angel Controller shows up in red in your screen? It happens a few seconds after you hit upload.
If you remove the USB-TTL cable from the computer, does COM6 disappear from the list?
Have you tried a different USB port in your computer?
With the USB-TTL cable connected in the computer and also connected into RA, unplug the computer end and plug it back in, while watching RA. Does RA reboot?
Lockes
Re: Error Uploading
Post by Lockes »
rimai wrote:Does RA reboot when the message Rebooting Reef Angel Controller shows up in red in your screen? It happens a few seconds after you hit upload. YES
If you remove the USB-TTL cable from the computer, does COM6 disappear from the list? YES
It reboots when I plug it in again
Re: Error Uploading
With the USB-TTL cable plugged in on both computer and RA, open Serial Monitor and make sure you have 57600 baud rate.
Tools->Serial Monitor
Also, make sure you have selected "Both NL & CR"
Type "GET /r99 " and make sure there is a space after /r99 and hit enter.
What do you get on the screen?
Lockes
Re: Error Uploading
Post by Lockes »
Getting nothing on the screen
Re: Error Uploading
At this point, I can't know for sure if the problem is the controller or the USB-TTL cable.
It's definitely a communication issue.
You will need to send the equipment back to be analyzed.
PM me for RMA.
Lockes
Re: Error Uploading
Post by Lockes »
What I did not notice earlier is when I remove the USB cable I got the following as text under the unsave arduino sketch
	at gnu.io.RXTXPort.eventLoop(Native Method)
	at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
Error inside Serial.serialEvent()
java.io.IOException: Bad file descriptor in nativeavailable
	at gnu.io.RXTXPort.nativeavailable(Native Method)
	at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532)
	at processing.app.Serial.serialEvent(Serial.java:258)
	at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
Re: Error Uploading
This will happen if you have serial monitor window opened when you pull out the USB cable.
Do you also have wifi attachment?
Lockes
Re: Error Uploading
Post by Lockes »
Yes I do.....
ok so only option is to get this to you. Must I work through the agent as I am based in South Africa?
Re: Error Uploading
Can you try using tera term or putty to connect to the wifi attachment?
What we are trying to do is verify if the usb-cable is working right.
Lockes
Re: Error Uploading
Post by Lockes »
wifi works 100%
DanJ70
Re: Error Uploading
Post by DanJ70 »
i am having the exact same issue i uploaded my original code when i received my reef angel using the wizard. It worked fine and i also have the wifi and salinity expansion. but ever since then i haven't been able to load any new code, i always get the same message and have tried all the normal solutions with no help.
Re: Error Uploading
Does it reboot a few seconds after you hit upload button?
Which RA do you have?
Can you post your error code shown in the screen?
DanJ70
Re: Error Uploading
Post by DanJ70 »
Yes i think it does, everything turns on. which brings me to another question if i dont want a port to turn on everytime it resets, should i label port not used instead of always on. I'm a newbie but i love my reef angel and travel alot id really like to get full usage of my reef angels potential. Im a big fan thank you for your help. here's the message i got after trying to upload.
Watchdog Timer
Version Menu
Dimming Signal
Salinity Expansion Module
Wifi Attachment
Custom Main Screen
Simple Menu
Binary sketch size: 28,194 bytes (of a 32,256 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -carduino -P\\.\COM4 -b115200 -D -Uflash:w:C:\Users\DANIEL~1\AppData\Local\Temp\build4719814583279372175.tmp\sketch_mar16a.cpp.hex:i
Copyright (c) 2000-2005 Brian Dean, /
Using Port : \\.\COM4
avrdude: Recv:
Re: Error Uploading
Is there any other serial port listed under Tools->Serial Port?
DanJ70
Re: Error Uploading
Post by DanJ70 »
I just recently purchased my reef angel and downloaded the programs so im assuming its the plus, i did get the upgraded memory and i do have a serial port 3 but been using port 4
Re: Error Uploading
Ok, change the board to Reef Angel Plus under Tools->Board
DanJ70
Re: Error Uploading
Post by DanJ70 »
ok Thank you i think that worked, i used the wizard and forgot to change that. I was wondering since i use my wifi and android app should i be installing the code on the internal memory.
