Awhile ago I was working on a light sensor for the aquarium. http://forum.reefangel.com/viewtopic.ph ... =cds#p4008 I finally got around to setting it up last weekend. I thought I'd share it with you all. I like that I can actually confirm the lights are on and maybe I'll be able to pick up a loss of lamp intenstiy over time. The pieces are really cheap. You just need to connect to the analog pins of an IO module or use a your own Arduino to connect to the RA.
Here is a picture of the meters I use. I just found these little containers at an art store and used a little silicone to seal the cable in and hold the photoresistor in place.
I used this code on my I/O module to smooth the signal and scale it to a single byte.
/* IO program has these functions:
Flow meters (skimmer, overflow, and phosban reactor)
Light sensors (2 readers connected to analog pins 0&1)
Autofeeder signal (signal output to the autofeeder relay)
Float sensors (overflow clog, reservoir empty)
#include <avr/wdt.h>
/* Photocell simple testing sketch. Connect one end of the photocell to 5V, the other end to Analog 0.
Then connect one end of a 10K resistor from Analog 0 to ground For more information see http://learn.adafruit.com/photocells */
int photocellPin = 0; // the cell and 10K pulldown are connected to a0
int photocellPin2 = 1;
int photocellReading; // the analog reading from the analog resistor divider
int photocellReading2; // the analog reading from the analog resistor divider
int photocelllevel;
int photocelllevel2;
// Define the number of samples to keep track of. The higher the number,
// the more the readings will be smoothed, but the slower the output will
// respond to the input. Using a constant rather than a normal variable lets
// use this value to determine the size of the readings array
const int numReadings = 10;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
const int numReadings2 = 10;
int readings2[numReadings2]; // the readings from the analog input
int index2 = 0; // the index of the current reading
int total2 = 0; // the running total
int average2 = 0; // the average
byte Overflow=0; //float in overflow box to turn off pump if clogged
byte Reservoir=0; //float in reservoir to keep from filling if empty
byte Feeder=0; //autofeeder signal
byte IOOut[11];
//flow meters
volatile int Flow0 = 0; //skimmer
volatile int Flow1 = 0; //overflow
volatile int Flow2 = 0; //phosban reactor
unsigned long lastmillis=millis();
void FlowMeter1()
Flow1++;
SIGNAL(PCINT0_vect) {
Flow0++;
SIGNAL(PCINT2_vect) {
Flow2++;
// Serial.begin(57600);
Wire.begin(7);
Wire.onRequest(requestEvent);
Wire.onReceive(receiveEvent);
pinMode(3,INPUT);
digitalWrite(3,HIGH); //pull up resistor
pinMode(5,INPUT);
digitalWrite(5,HIGH); //pull up resistor
pinMode(6,INPUT);
digitalWrite(6,HIGH); //pull up resistor
pinMode(9,INPUT);
digitalWrite(9,HIGH); //pull up resistor
pinMode(10,OUTPUT);
digitalWrite(10,LOW); //pull up resistor
pinMode(11,INPUT);
digitalWrite(11,HIGH); //pull up resistor
PCMSK0 |= (1<<PCINT3); // Pin 11
PCICR |= (1<<PCIE0); // Interrupt 0
PCMSK2 |= (1<<PCINT21); // Pin 5
PCICR |= (1<<PCIE2); // Interrupt 2
MCUCR = (1<<ISC01) | (1<<ISC01); //Rising edge
attachInterrupt(1, FlowMeter1, RISING); // Interrupt 1
wdt_enable(WDTO_1S);
wdt_reset();
//smoothing functions on cds
photocellReading = analogRead(photocellPin);
photocellReading2 = analogRead(photocellPin2);
photocelllevel = map(photocellReading, 0, 1023, 0, 255);
total = total - readings[index]; // subtract the last reading:
readings[index] = photocelllevel; // read from the sensor:
total = total + readings[index]; // add the reading to the total:
index = index + 1; // advance to the next position in the array:
if (index >= numReadings) // if we're at the end of the array...
index = 0; // ...wrap around to the beginning:
average = total / numReadings; // calculate the average:
photocelllevel2 = map(photocellReading2, 0, 1023, 0, 255);
total2 = total2 - readings2[index2]; // subtract the last reading:
readings2[index2] = photocelllevel2; // read from the sensor:
total2 = total2 + readings2[index2]; // add the reading to the total:
index2 = index2 + 1; // advance to the next position in the array:
if (index2 >= numReadings2) // if we're at the end of the array...
index2 = 0; // ...wrap around to the beginning:
average2 = total2 / numReadings2; // calculate the average:
if (millis()-lastmillis>1000)
IOOut[0]=0;
IOOut[1]=Flow0>>8;
IOOut[2]=Flow0;
IOOut[3]=Flow1>>8;
IOOut[4]=Flow1;
IOOut[5]=Flow2>>8;
IOOut[6]=Flow2;
Flow0=0;
Flow1=0;
Flow2=0;
//overflow sensor
Overflow = digitalRead(6);
//reservoir sensor
Reservoir = digitalRead(9);
IOOut[7]=Overflow;
IOOut[8]=Reservoir;
IOOut[9]=average;
IOOut[10]=average2;
//overtemp alarm
if (Feeder == 0)
digitalWrite(10, LOW);
else if (Feeder == 1)
digitalWrite(10, HIGH);
void requestEvent() {
Wire.write(IOOut,sizeof(IOOut));
void receiveEvent(int howMany)
if (howMany==4) // Our custom protocol is 4 bytes
byte cmd1,cmd2,cmd3,cmd4;
cmd1=Wire.read();
cmd2=Wire.read();
cmd3=Wire.read();
cmd4=Wire.read();
if (cmd1=='$' && cmd2=='$' && cmd3=='$') // the first 3 bytes of the custom protocol are $$$ to ensure it's coming from RA
Feeder=cmd4;
for (int a=0;a<howMany;a++)
Wire.read(); // if the number of bytes is not 4, discard everything
Let me know if anyone wants more info or if some of you more expreienced programmers could clean up my amateur code.
Jon
