Hello,
I'm trying to piece together my controller, and one of the things I would like is the moonlights. I'm just not sure if I have enough equipment to do 2 moonlights.
I currently just have the main controller package with 1 relay box.
I'm looking at buying the Relay Expansion Module + Relay Box here shortly, plus an additional temperature probe.
Between the two relay boxes, do I have enough (or any) boosted PWM ports to plug up 2 moonlights?
What is needed for Moonlights?
Re: What is needed for Moonlights?
The main relay box you have can power 2 dimmable moonlights.
agentgreen
Awesome, they just plug up to where the LEDs would?rimai wrote:The main relay box you have can power 2 dimmable moonlights.
Yes, you just plug them into each PWM output channel.
The expansion relay boxes will not add additional channels. To get more PWM channels, you will need a PWM expansion module.
agentgreen
Gotcha, all I need (at this point) is two.
