Mounting Bracket
Mounting Bracket
Any ideas for mounting brackets for the controller? I know there was a discussion on the mailing list last summer but I didn't know if anything further has been done.
Re: Mounting Bracket
I use velcro.
I'm not sure what others do, but I'd love to have a supplier of mounting brackets.
alexwbush
Post by alexwbush »
abs plastic + heat gun to make my bracket
agentgreen
Post by agentgreen »
alexwbush wrote:abs plastic + heat gun to make my bracket
That is really nice. Can you elaborate a little on how you did it? Eg. where you got the plastic from, how you did the molding...
NanoTrevor
Post by NanoTrevor »
hey roberto, just a gee whiz, how hard would it be to have all the brains of the ra inside a separate housing and the display by itself with one cable connecting it to the brain box? this way all the wires for temp, pwm, ph, etc can mount to a non moveable location and the display could be easier to mount somewhere remotely??
Not to hard, but I don't know how far you would be able to strech the signals from the main board. Never tested it.
But, I don't think this will ever be tested or tried, considering the fact that a new display module is being prototyped.
NanoTrevor
huh? really? thats not fair :O( i want one.
alexwbush
Post by alexwbush »
sorry, I didn't see this sooner. It's made of black abs plastic. I bought a sheet from a plastic shop and used a heat gun, then molded it around my RA.
NanoTrevor
rimai wrote:Not to hard, but I don't know how far you would be able to strech the signals from the main board. Never tested it.
so anymore info available at this point? you say display module? is it just that only the display? or will it be similar to current with ph, temp, ato, etc connections?
I'll have more info in a couple weeks when I get proto boards made.
serhiyi
Post by serhiyi »
I ordered this http://www.dealextreme.com/p/universal- ... lack-81053
looks like it can work. will post results when I get it.
Nice finding :)
Let us know how it looks and if you can post a picture, it would be awesome!!
serhiyi
Post by serhiyi »
It took some time to get this holder. Then I went for a short vacation... Anyway, I'm ready to share some pictures.
Cell phone holder with suction mount.
There are two raised parts at the bottom of the holder that prevent controller from mounting flat (circled with red).
Trying to mount controller.
Another view of bumps.
To be cont...
serhiyi
Post by serhiyi »
Those bumps must go:
Bumps must go
Bumps must go
One is out. One to go.
To be cont...
serhiyi
Post by serhiyi »
Now it fits better:
Front view
Front view
Back
Back
Side view
Side view
To be cont...
serhiyi
Post by serhiyi »
Mounting to the door using double sided tape.
Bottom view
Bottom view
Tape
Tape
Ready to attach
Ready to attach
To be cont...
serhiyi
Post by serhiyi »
Holder mounted to the door.
Side view with controller.
Final result.
Final result.
I should say that it's not the best mount I could imagine, but it does the trick.
You have to remove bumps for better fit. I also removed one padding on each side of the mount.
But it is not half bad for $5 delivered.
You can try to use suction mount, but I did not see any good from it in my application. The only way I can think of is to mount it to the side of tank or sump, but I want to keep controller as far from water as possible.
Very cool!! 8-)
Nice. Looks good. :)
