Help with Airport please
Badger55
Ok so every time I set the AirPort Extreme to open port 2000 on a specific IP address the wifi controller jumps to a different ip. 5 hours and its still killing me. I give up for the night. All other functions seem to be fine and direct connect works.
Reefcam: dansreef.swanndvr.net login: guest pw: guest
Badger55
Thanks. I'll try it today.
Badger55
Re: Help with Airport please
Not working followed the instructions to the letter, it still changes the address of the wifi adapter as soon as I set the port mapping.
Badger55
ok not sure how I got it but I did. Now my question is how do I know that the program is running and not on some sort of override from pushing buttons on the iPad?
On the ipad if you see blue dots next to your relays they are overrides. Click them and the relays will go back to their "normally scheduled program"
Badger55
Thanks, my code must be off because when I hit the blue dot's for ports that should be on (main pump) it shuts off.
Badger55
Does the ra need to be plugged into the computer to use the wizard or is there a way to use wifi?
dbmet
Badger55
