Relay sticking
Relay sticking
I have a relay sticking all of a sudden. I'm going to change the port to an open slot. But how can I fix it? What would u recommend?
Re: Relay sticking
It's your MH ballast, ain't it?
You can replace the relay yourself or send it for repair.
http://forum.reefangel.com/viewtopic.php?p=14834#p14834
Re: Relay sticking
No. Its t5 actnic. MH is perfect. I searched first and saw leds or MH usually trip it but not t5. Eh whatever I just couldn't figure out of I should bypass that port since I have extras or repair?
Re: Relay sticking
I'll order the relay and give it a go. Off your head u think any local places would have it?
Re: Relay sticking
What causes the relays to fail?
Re: Relay sticking
The most likely cause is in-rush current.
When current is too high, the electricity travel through the air in the form of a spark when the contacts are coming in contact, just before they close. This spark is enough to heat up the contacts that they melt and fuse together when the relay actually closes.
- DrewPalmer04
Re: Relay sticking
Omron G2RL-1A4-E
