Heater port wont turn on and menu question
ecam
Post by ecam »
Here is my code. Can someone tell me why the heater is not following instructions and coming on....
Also how can i get the Vortech mode to show on my menu? Thanks
byte vtechmode;
boolean bFeeding=false;
ReefAngel.Init(); // Initialize Controller
ReefAngel.AddStandardMenu();
ReefAngel.AddDateTimeMenu();
ReefAngel.WaterChangePorts = Port1Bit | Port8Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
ReefAngel.FeedingModePorts = Port1Bit | Port6Bit | Port8Bit; // Turn off Ports 1, 6, 7 and 8 when Water Change Mode is activated
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit; // Turn off Ports 3, 4 and 7 when overheat occurs
ReefAngel.RF.SetMode( NutrientTransport,85,10 );
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit| Port5Bit; // Turn on/off Ports 3 and 4 when Light On/Off menu option is selected
ReefAngel.Relay.On( Port1 ); // Return Pump
// Hardcode PH calibrations
ReefAngel.PHMin=544; // PH7.0
ReefAngel.PHMax=830; // PH10.0
ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,COLOR_WHITE,28,121,"Edwin's Reef"); // Display Reef Angel banner
//Light instructions
ReefAngel.StandardLights( Port2,19,15,7,4 );//Refugium
ReefAngel.StandardLights(Port3,7,5,19,15); // Actinic Lights
ReefAngel.StandardLights(Port4,9,5,17,0); // Daylight Lights
ReefAngel.StandardLights(Port5,9,5,17,0); // Daylight Lights - MH
ReefAngel.StandardHeater( Port7,750,810 );
ReefAngel.Relay.DelayedOn( Port8,2 ); //Skimmer
//Light instructions (Start Hr,Min, End Hr, Min)
//ReefAngel.Wavemaker1(Port5); // Wavemaker 1
//ReefAngel.Wavemaker2(Port6); // Wavemaker 2
ReefAngel.PWM.StandardDaylight(); // Dimming for Daylight Channel
ReefAngel.PWM.StandardActinic(30); // Dimming for Actinic Channel
//-------------------------------------------------------- Start RF Nightmode Control ---------------------------------------------
if (hour()>=23 || hour()<7) // Defining "Nightmode" hours for VorTech = between 11 PM and 7 AM
ReefAngel.RF.UseMemory=false;
vtechmode = 9;
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
ReefAngel.RF.UseMemory=true;
vtechmode = InternalMemory.RFMode_read();
//---------------------------------------------------------- End RF Nightmode Control ---------------------------------------------
What temp are you seeing on t3?
Can you confirm your heater is on port 7?
ecam
Re: Heater port wont turn on and menu question
Post by ecam »
lnevo wrote:What temp are you seeing on t3?
Temp is 80.0
and it is on prt 7
You might have an override set...what happens if you manually turn the port on?
ecam
Post by ecam »
lnevo wrote:You might have an override set...what happens if you manually turn the port on?
it works if i turn on manually. but then it doesnt turn off
Piper
Post by Piper »
Has your temp dropped to 75.0 yet? It's not going to come on till it hits 75.0
Ahh good point. I forgot to look more closely. You usually want to have only 1-2 or even less of a spread between the on / off values. I have mine set at 798 802.
Also if you leave the values blank and just pass the relay you can set the values through the portal so you can tune it easier..assuming you have the wifi working properly.
ecam
Post by ecam »
Thanks guys. I realized that yesterday after it was pointed out. Thanks.
lnevo wrote:Ahh good point. I forgot to look more closely. You usually want to have only 1-2 or even less of a spread between the on / off values. I have mine set at 798 802.
