Hi,
The clock on one of our new reef angels is resetting randomly, so it goes back to the default time.
Then we set the correct time again, but when I look a little later, the clock is reset. I think it is not a power issue, and the backup battery inside had 3 volts power.
Any suggestions?
Remco
Clock keeps resetting...
rwijbenga
rwijbenga
Re: Clock keeps resetting...
With the RA client suite and with the timesetting URL in à browser.
We use wifi to connect.
The time setup menu is not used in our pde.
- Contact:
What version of the software are you running? There was some earlier versions that I did not handle setting the date properly (ie, synchronizing the RTC).
rwijbenga
The latest version, 2.2
And the latest dev libraries. 8.5.16
rwijbenga
We have fixed it !
We have uploaded the original reef Angel lit pde. Set the time in the setup menu and placed our PDE back again.
So settintg the time over wifi is not working correctly.....
I think the latest library .16 still do not have the patch.
I'm sure you will find it will work on the next release.
rwijbenga
Super !
Let's hope .17 is just arround the corner.
