Wavemaker code help
Wavemaker code help
Looking to have my wavemaker on Port 6 turn on at 8:00am and turn off at 7:00pm. Current code below.
Thanks in advance.
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 940 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardATO( Port1,30 );
ReefAngel.StandardFan( Port3,765,780 );
ReefAngel.StandardLights( Port4,7,30,22,0 );
ReefAngel.WavemakerRandom( Port6,60,300 );
ReefAngel.Portal( "treetopflyn" );
Thanks in advance.
Re: Wavemaker code help
Replace this:
With this:
if (hour()>=8 && hour()<19)
ReefAngel.Relay.Off(Port6);
As usual thank you very much!!
Finally got around to messing with this been working like a dog. For some reason port 6 is not coming on now
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit;
ReefAngel.WavemakerRandom( Port5,600,1800 );
It's because of the Port5 using the same function.
Do you also want port5 to be totally random and work all the time?
Yes. 5 is my Jebo WP-40 that has the light sensor so it cranks down at night. I would like it to stay on. Actually if possible I would like port 6 to go on an off at 5 min intervals. I am tired of hearing the damn clicking of the Korilla all the time.
Of course once I get the harness and some codes are written I will switch the WP40 to be controlled fully by the RA
Thanks for your help.
K
K
Try this:
ReefAngel.Wavemaker( Port6,300 );
I have a few questions about the WP40.
Kevin said he is running at 16v right now, Ive seen the video and thats too much flow for my placement. What is the operating voltage range on that pump. I would love to have one of these. How much could I dial it down once Roberto has the harness ready? My understanding it the WP25 may be more for nano reefs. Any input would be great.
The operating voltage is 24V.
What the person you mentioned is probably doing is a hack work around in my point of view.... lol
He is reducing the operating voltage to try to reduce the speed.
Why?
Because he probably has no other means of controlling the speed and he's trying to use the controller that came with it.
With RA, you can set the speed to whatever you want and still operate at 24V, which the pump was designed to do.
The lowest speed is pretty low. Not as low as a Vortech in night mode, but it's very low.
The highest speed is very good flow and you can go anywhere in between and create any waveform you wish
Why?
That is exactly what I am doing. As soon as the harness is ready (hint hint), I will run at 24v controlling it with the RA.rimai wrote:The operating voltage is 24V.
Why?
