Client Suite 3.0
civictuner04
Re: Client Suite 3.0
Post by civictuner04 »
man roberto you are the man thank you :)
acabano
Post by acabano »
after installing the ini file i got this error..
*****1/19/2013 7:56:48 AM*****
Message:
Value cannot be null.
Parameter name: String
StackTrace:
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at System.Int32.Parse(String s)
at ReefAngelClient.Form1.DisplayMemoryValues()
dmolton
Post by dmolton »
Just pushed a new release (3.0.1) which is ready to download. This release addresses minor UI inconsistencies between the Client and the RA Wizard. Mainly deprecated ATO memory values and MH settings. In addition it should resolve an issue with the Notification Service that stopped it from pushing data to the Portal while connected via USB. The first post of this thread includes the full changelog and the download link has been updated accordingly.
-Dave
acabano
Post by acabano »
Thanks, Got it working now.
Arnee.
smoothdog
Post by smoothdog »
Can the listener service app config be edited to change the polling frequency?
Scratch that, after looking closer I see the listener is real time. How do I change the logging frequency in the client app? It is updating every 3 min but sometimes every 4min so I'm assuming it's logging around every 3.1 min.
ibmlmjm
Post by ibmlmjm »
Dave,
Is there any chance of getting the latest source too listener & Logger?
Thanx,
Michael
rossbryant1956
Post by rossbryant1956 »
Dave, will you be supporting the ph expansion, the salinity expansion units any time soon? Love your product!
Also, how do I use the min, max, and average temp values shown on the pictures? Thx
jtomasi
Post by jtomasi »
Is there anyway to see the value of my water level at certain intervals? or when a specific relay is turned on? I use the water level instead of the ATO switches and would like too see when and how often it reaches the high/low thresholds I set. If it is being log in a memory file, where can I access that? It would be awesome to graph the WL % :D
JP
Client Suite 3.0
jtomasi
Post by jtomasi »
Thank You!
dmolton
Post by dmolton »
smoothdog wrote:Can the listener service app config be edited to change the polling frequency?
The live parameters get updated 15 seconds on screen (Temp, PH, ATO, Relays etc...). The chart will get updated every 3 minutes if you're viewing the Live (24hr) view of the chart or grid. Parameters will get stored in the database every 6 minutes. I believe data will be pushed to the portal every 5 minutes. Some of these used to be configurable but that option was removed to avoid errors when setting the timespan too low.
How often were you looking to poll?
ibmlmjm wrote:Dave,
Thanx,
Michael
I'm finishing up a new API to communicate with the controller/portal that I'm using in the Store App. The source code and .dll will be available on github shortly.
rossbryant1956 wrote:Dave, will you be supporting the ph expansion, the salinity expansion units any time soon? Love your product!
Thanks, Ross. Salinity is already supported - have a look at the General Tab in settings to enable it. This is also where you get the min/max/avg calculations. Check the "Display aggregate values" checkbox in that tab also. I'll work on getting the pH expansion working as well!
jtomasi wrote:Is there anyway to see the value of my water level at certain intervals? or when a specific relay is turned on? I use the water level instead of the ATO switches and would like too see when and how often it reaches the high/low thresholds I set. If it is being log in a memory file, where can I access that? It would be awesome to graph the WL % :D
JP
I recently received and hooked up a water level sensor as well and already have a rough implementation of it in the desktop client. SMS/Email notification alerts need to implemented for water level, salinity and the pH expansion as well.
Water Level/ Salinity on the Client:
Paulturner911
Post by Paulturner911 »
Im getting "Error 1920" during install at starting services.
dmolton
Post by dmolton »
Paulturner911 wrote:Im getting "Error 1920" during install at starting services.
Is there any more to the message other than Error 1920? Can you confirm you have the .Net Framework 4.0 installed? What version of Windows?
Paulturner911
I do have .net 4, Im on XP. Its a list of errors...probably not your problem. I managed to get it installed and then reads cannot open because it is configured incorrectly. Do you have an email address you could pm me so that I could send you a picture of the error?
saf1
Post by saf1 »
Question on the Client Suite v3.0.
Does it still support adjusting the PWM percentage?
I believe that the earlier version allowed you to adjust it via the sliders. This one does too, but it never actually changes. It displays the precentage but then goes back to the current settings via the controller. No matter what I do, it stays.
I was trying to get the color ration set because I think the LED's are a bit too blue.
It does, as long as you override the port that was selected as lights on.
So, for example your code has a line like this:
ReefAngel.LightsOnPorts = Port2Bit;
If you override port 2 to always on, you can use the sliders.
saf1
Post by saf1 »
Hi, and thanks for the reply. I don't recall changing that but I went ahead and pulled up a sketch and see it is set to 0.
The next question is how do I know that is the sketch that is loaded? Is there anyway to tell on the actuall device?
Thanks again.
You would need to look at the code you uploaded to the controller.
saf1
Post by saf1 »
Hi Rimai,
I tried setting the Port2Bit as you suggested but it still isn't doing the trick and allowing me to adjust the lighting per the client. In fact, I'm not even sure the client is pulling the correct memory settings oddly enough. I know it is working but maybe I don't have it configured correctly. Everything is working as it should though as my lights come on, off via PWM as I set. I even tested it this morning by changing the start time from 10 to 7.
Not sure if I can post the code, but I will try:
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit;
InternalMemory.OverheatTemp_write( 880 );
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardLights( Port4,07,0,22,30 );
ReefAngel.PWM.SetDaylight( PWMParabola(11,0,20,0,1,100,1) );
ReefAngel.PWM.SetActinic( PWMParabola(10,0,21,0,1,90,1) );
ReefAngel.Portal( "saf1" );
int x,y;
// Parameters
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,66, ReefAngel.Params.PHExp );
// Main Relay Box
// Date and Time
Ok, the code looks good.
Now, on the client, override port 2 to always on instead of auto.
Does it change now?
saf1
Post by saf1 »
Ok, that did the trick. Thanks. I figured there was something that I wasn't doing. Even though it was on, it wasn't set to always like you pointed out.
Thank you much. Appreciate the help.
Paulturner911
This is the error I am getting trying to run the program. I can run the dashboard and listener will run, logger will run, but when I switch notifier on, logger will stop.
I've been getting this since the library upgrade:
Any thoughts?
Yeah, we need Dave to fix the Client... :(
It happened before:
http://forum.reefangel.com/viewtopic.php?p=16602#p16602
Everytime there is an internal memory added, it's going to break the Client.
I think this new file may fix it...
Want to try it?
Seems to have fixed it. I had to exit out and restart after I loaded the memory file.
Thanks, Roberto!
Paulturner911
Anyone wanna chime in on my error?
Ademster
Post by Ademster »
Next time this is updated, can we add the ability to see the expansion modules?
ie: ph expan, orp, water level, etc?
and all be part of the graphs?
and maybe have the ability to separate them all?
Adam
58 Gal
enigma32
Post by enigma32 »
@Paulturner911:
It seems to be usually related to the VC++ redistributable... I imagine the installer ensures that you have the right one though. (Perhaps it doesn't, or maybe if it used to work you have installed something that changed the version of the library you had...)
Maybe try reinstalling the client?
Otherwise I think you'll have to wait for the author or someone else familiar with .Net programming to respond... I won't touch that stuff ;)
Current setup:
60g 24" custom cube (fish and softies right now)
AI Sol Blue, Ecotech MP-10wES
Coralife skimmer
100% customer controller, transitioning to ReefAngel
For v1.0.7, you need this new ini file.
rossbryant1956
save this file where?
