My code - now with RAnet
PostPosted: Wed Mar 20, 2013 4:53 pm
ReefAngel Plus with RAnet relay expansion, Vortech, Salinity, pH, Temp, wifi, RAnet pwm, water level and ATO
PostPosted: Wed Mar 20, 2013 7:02 pm
This post will always be my most current code
09/24/2015
        #include <SoftwareSerial.h>
    #define Heater      1
    #define Return      2
    #define             3
    #define Skimmer     4
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
    #define Sump Light  8
byte vtechmode, vtSpeed, vtDuration;
        ReefAngel.FeedingModePortsE[0] = Port2Bit;
        ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit;
        ReefAngel.AddRANet();
        ReefAngel.Relay.On( Port2 );
        ReefAngel.Relay.On( Port3 );
        ReefAngel.Relay.On( Port4 );
        ReefAngel.Relay.On( Port7 );
        // Hardcode calibrations
       ReefAngel.PHMin=576; // PH7.0
       ReefAngel.PHMax=842; // PH10.0
      //  ReefAngel.SalMax=3300; // 35ppt
    vtechmode=InternalMemory.RFMode_read();
    vtSpeed=InternalMemory.RFSpeed_read();
    vtDuration=InternalMemory.RFDuration_read();
    static unsigned long feeding;
    ReefAngel.StandardHeater( Port1,778,782 );
      //  ReefAngel.WaterLevelATO( Port7,180,71,74 );
    //    ReefAngel.StandardLights( Port8,15,0,2,0 );
        ReefAngel.PWM.SetChannel( 0,PWMSlope(13,40,21,00,0,0,40,0) );  //LIME
        ReefAngel.PWM.SetChannel( 1,PWMSlope(13,40,22,00,15,100,30,0) );  //RB
        ReefAngel.PWM.SetChannel( 2,PWMSlope(13,40,21,00,15,100,30,0) ); //WHITE
        ReefAngel.PWM.SetChannel( 3,PWMSlope(13,40,21,00,15,80,30,0) );  //BLUE&CYAN
        ReefAngel.PWM.SetChannel( 4,PWMSlope(13,40,21,00,15,80,30,0) ); //UV
        if ( ReefAngel.HighATO.IsActive())
          ReefAngel.Relay.On(Port2);
          ReefAngel.Relay.Off(Port2);
if (now() % 10800 == 0 ) while(1);
if (hour() >=12 && hour() < 21)
        // if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
        ReefAngel.RF.UseMemory=true;
        // ReefAngel.RF.SetMode(ReefCrest,60,20);
             feeding=now();
             if (now()-feeding<5400) {
            // if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 90 minutes after feeding mode.
  ReefAngel.RF.UseMemory=false;
    ReefAngel.RF.SetMode(Smart_NTM,75,10);
        ReefAngel.RF.SetMode(Constant,10,0);
         if (vtechmode!=InternalMemory.RFMode_read())
          InternalMemory.RFMode_write(vtechmode);
         if (vtSpeed!=InternalMemory.RFSpeed_read())
          InternalMemory.RFSpeed_write(vtSpeed);
         if (vtDuration!=InternalMemory.RFDuration_read())
          InternalMemory.RFDuration_write(vtDuration);
        ReefAngel.Portal( "bencollinz" );
      char text[7];
        // Date and Time
        ReefAngel.LCD.DrawDate( 6, 2 );
    ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
  else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:");
  ReefAngel.LCD.Clear(255,59,29,128,39);
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed);
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/");
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration);
  ReefAngel.LCD.DrawText(0,255,10,40,"Salt");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,40,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,13,58,"Salinity");
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8);
  // water level
    ReefAngel.LCD.DrawText(0,255,68,58,"WL");
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() );
       // Main Relay Box
        ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay );
         // Relay Expansion
       ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay );
PostPosted: Wed Mar 20, 2013 7:10 pm
I'm uploading to internal memory btw
PostPosted: Wed Mar 20, 2013 7:16 pm
and my damn heater temps as well...I'm lost.
PostPosted: Wed Mar 20, 2013 9:15 pm
Did you try going with hard coded settings to get familiar?
PostPosted: Fri Mar 22, 2013 8:40 am
rimai wrote:Did you try going with hard coded settings to get familiar?
this better?
        ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port7Bit | Port4Bit | Port5Bit | Port6Bit;
   // Hardcode PH calibrations
        ReefAngel.StandardHeater( Port1,796,802 );
        ReefAngel.WaterLevelATO( Port7,60,52,58 ); // 60 seconds timeout, turn on at 52% and turn off at 58%
        ReefAngel.PWM.SetChannel( 0, MoonPhase() );
        ReefAngel.PWM.Channel1PWMParabola();
        ReefAngel.PWM.Channel2PWMParabola();
        ReefAngel.PWM.Channel3PWMParabola();
        ReefAngel.PWM.Channel4PWMSlope();
        ReefAngel.RF.UseMemory = true;
        int x,y;
        // Dimming Expansion
        x = 15;
        y = 2;
        for ( int a=0;a<6;a++ )
          if ( a>2 ) x = 75;
          if ( a==3 ) y = 2;
          y += 10;
        // Parameters
        ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params,
        ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params );
        // Salinity
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,68, "SAL:" );
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,68, ReefAngel.Params.Salinity );
        // pH Expansion
        // ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,82, "PHE:" );
        // ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,82, ReefAngel.Params.PHExp );
        // pingSerial();
        // Water Level
        ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,82, "WL:" );
        ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,82, ReefAngel.WaterLevel.GetLevel() );
        // Main Relay Box
        ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
        // Date and Time
Can I hard code the SALINITY calibration as well?
PostPosted: Fri Mar 22, 2013 8:48 am
Yes, looks good.
You can hardcode sal calibration like this:
      ReefAngel.SalMax=2250; // 35ppt
PostPosted: Fri Mar 22, 2013 12:39 pm
rimai wrote:Yes, looks good.
should I use 2250 or 2998 that shows on the controller when I calibrate with fluid?
PostPosted: Fri Mar 22, 2013 12:56 pm
Yeah, whatever number you have it when calibrating.
I'm just trying to show you how to do it.
PostPosted: Sun Mar 24, 2013 8:19 am
so i'm using this code now...
        ReefAngel.SalMax=3000; // 35ppt
        int x,y;
        x = 15;
        y = 2;
          if ( a>2 ) x = 75;
          if ( a==3 ) y = 2;
          y += 10;
        // Parameters
        // Salinity
        // pH Expansion
        // pingSerial();
        // Water Level
        // Main Relay Box
        // Date and Time
it makes a red light on the RA controller come on, until I choose clear ATO from the menu but then it unchooses auto and on goes to on. if I change it back to auto via portal I get the red light again and it stops working.
advice?
Next
Return to My PDE/INO file
