My code - now with RAnet
bencollinz
Post by bencollinz »
ReefAngel Plus with RAnet relay expansion, Vortech, Salinity, pH, Temp, wifi, RAnet pwm, water level and ATO
bencollinz
Re: My code - water level ATO help needed
This post will always be my most current code
09/24/2015
        #include <SoftwareSerial.h>
    #define Heater      1
    #define Return      2
    #define             3
    #define Skimmer     4
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
    #define Sump Light  8
byte vtechmode, vtSpeed, vtDuration;
        ReefAngel.FeedingModePortsE[0] = Port2Bit;
        ReefAngel.OverheatShutoffPortsE[0] = Port1Bit | Port2Bit;
        ReefAngel.AddRANet();
        ReefAngel.Relay.On( Port2 );
        ReefAngel.Relay.On( Port3 );
        ReefAngel.Relay.On( Port4 );
        ReefAngel.Relay.On( Port5 );
        ReefAngel.Relay.On( Port7 );
        // Hardcode calibrations
       ReefAngel.PHMin=576; // PH7.0
       ReefAngel.PHMax=842; // PH10.0
      //  ReefAngel.SalMax=3300; // 35ppt
    vtechmode=InternalMemory.RFMode_read();
    vtSpeed=InternalMemory.RFSpeed_read();
    vtDuration=InternalMemory.RFDuration_read();
    static unsigned long feeding;
    ReefAngel.StandardHeater( Port1,778,782 );
      //  ReefAngel.WaterLevelATO( Port7,180,71,74 );
    //    ReefAngel.StandardLights( Port8,15,0,2,0 );
        ReefAngel.PWM.SetChannel( 0,PWMSlope(13,40,21,00,0,0,40,0) );  //LIME
        ReefAngel.PWM.SetChannel( 1,PWMSlope(13,40,22,00,15,100,30,0) );  //RB
        ReefAngel.PWM.SetChannel( 2,PWMSlope(13,40,21,00,15,100,30,0) ); //WHITE
        ReefAngel.PWM.SetChannel( 3,PWMSlope(13,40,21,00,15,80,30,0) );  //BLUE&CYAN
        ReefAngel.PWM.SetChannel( 4,PWMSlope(13,40,21,00,15,80,30,0) ); //UV
        if ( ReefAngel.HighATO.IsActive())
          ReefAngel.Relay.On(Port2);
          ReefAngel.Relay.Off(Port2);
if (now() % 10800 == 0 ) while(1);
if (hour() >=12 && hour() < 21)
        // if (ReefAngel.RF.Mode==Night) ReefAngel.RF.SetMode(Feeding_Stop,0,0);
        ReefAngel.RF.UseMemory=true;
        // ReefAngel.RF.SetMode(ReefCrest,60,20);
             feeding=now();
             if (now()-feeding<5400) {
            // if (now()-feeding > 1 && now()-feeding < 5400) { // 1 second after feeding mode until 90 minutes after feeding mode.
  ReefAngel.RF.UseMemory=false;
    ReefAngel.RF.SetMode(Smart_NTM,75,10);
        ReefAngel.RF.SetMode(Constant,10,0);
         if (vtechmode!=InternalMemory.RFMode_read())
          InternalMemory.RFMode_write(vtechmode);
         if (vtSpeed!=InternalMemory.RFSpeed_read())
          InternalMemory.RFSpeed_write(vtSpeed);
         if (vtDuration!=InternalMemory.RFDuration_read())
          InternalMemory.RFDuration_write(vtDuration);
        ReefAngel.Portal( "bencollinz" );
      char text[7];
        ReefAngel.LCD.DrawDate( 6, 2 );
    ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
  else if (vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,4,30,"RF Speed:");
  ReefAngel.LCD.Clear(255,59,29,128,39);
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,71,31,vtSpeed);
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,90,31,"/");
  ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,100,31,vtDuration);
  ReefAngel.LCD.DrawText(0,255,10,40,"Salt");
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 50, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,40,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 50, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,13,58,"Salinity");
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 13, 68, text, Num8x8);
  // water level
    ReefAngel.LCD.DrawText(0,255,68,58,"WL");
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 68, 68, ReefAngel.WaterLevel.GetLevel() );
        ReefAngel.LCD.DrawOutletBox( 12, 108, TempRelay );
         // Relay Expansion
       ReefAngel.LCD.DrawOutletBox( 12, 120, TempRelay );
bencollinz
I'm uploading to internal memory btw
bencollinz
and my damn heater temps as well...I'm lost.
Did you try going with hard coded settings to get familiar?
bencollinz
rimai wrote:Did you try going with hard coded settings to get familiar?
this better?
        ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.WaterChangePorts = Port7Bit | Port4Bit | Port5Bit | Port6Bit;
        ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port7Bit | Port4Bit | Port5Bit | Port6Bit;
	// Hardcode PH calibrations
        ReefAngel.StandardHeater( Port1,796,802 );
        ReefAngel.WaterLevelATO( Port7,60,52,58 ); // 60 seconds timeout, turn on at 52% and turn off at 58%
        ReefAngel.PWM.SetChannel( 0, MoonPhase() );
        ReefAngel.PWM.Channel1PWMParabola();
        ReefAngel.PWM.Channel2PWMParabola();
        ReefAngel.PWM.Channel3PWMParabola();
        int x,y;
        // Dimming Expansion
        x = 15;
        y = 2;
        for ( int a=0;a<6;a++ )
          if ( a>2 ) x = 75;
          if ( a==3 ) y = 2;
          y += 10;
        ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params,
        ReefAngel.LCD.DrawMonitor( 15, 35, ReefAngel.Params );
        // Salinity
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,68, "SAL:" );
        ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,68, ReefAngel.Params.Salinity );
        // pH Expansion
        // ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,82, "PHE:" );
        // ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,82, ReefAngel.Params.PHExp );
        // pingSerial();
        // Water Level
        ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,82, "WL:" );
        ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,82, ReefAngel.WaterLevel.GetLevel() );
        ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
Can I hard code the SALINITY calibration as well?
Yes, looks good.
You can hardcode sal calibration like this:
      ReefAngel.SalMax=2250; // 35ppt
bencollinz
rimai wrote:Yes, looks good.
should I use 2250 or 2998 that shows on the controller when I calibrate with fluid?
Yeah, whatever number you have it when calibrating.
I'm just trying to show you how to do it.
bencollinz
so i'm using this code now...
        ReefAngel.SalMax=3000; // 35ppt
        int x,y;
        x = 15;
        y = 2;
          if ( a>2 ) x = 75;
          if ( a==3 ) y = 2;
          y += 10;
        // Salinity
        // pH Expansion
        // pingSerial();
        // Water Level
it makes a red light on the RA controller come on, until I choose clear ATO from the menu but then it unchooses auto and on goes to on. if I change it back to auto via portal I get the red light again and it stops working.
advice?
Does the red light turns on immediately or it turns on after 60 seconds?
bencollinz
rimai wrote:Does the red light turns on immediately or it turns on after 60 seconds?
ok, so I unplugged RA and plugged back in. no red light. ATO is on auto per portal. water level is at 55 currently, so it should be running but it's not.
I turn it to on manually, it doesn't shut off when it hits 60 seconds or 58% water level. If I set it back to auto it stays off.
the portal still says water is 55% but RA says 59%
unfortunately, I couldn't reproduce the red light issue now.
It won't turn on until it reaches 52%. That's what you set it at.
It turns on at 52% and off at 58%.
So, when the level does get to 52, you have 60 seconds to pump water until it hits 58% or the timeout will happen and disable the ATO. This is a safety feature to prevent overflow. That's when the red light goes on, indicating an ATO timeout.
So, I think you are using too high of a range and too low of a timeout. Can you pump that much water in 60 seconds?
It will never shut off if you turn on manually. That's what we call override. You are forcing an on position situation no matter what the controller thinks it should be.
bencollinz
rimai wrote:It won't turn on until it reaches 52%. That's what you set it at.
I found this is someone else's thread http://forum.reefangel.com/viewtopic.ph ... ion#p14563
  // If water level less than 58, turn on auto top off relay; else, keep it off
  if (ReefAngel.WaterLevel.GetLevel()<58) ReefAngel.Relay.On(Port7);
  else ReefAngel.Relay.Off(Port7);
can I use that instead?
or does it still need a timeout, just in case?
Yeah, you can use that.
bencollinz
    #define Heater      1
    #define Return      2
    #define Skimmer     3
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
byte vtechmode;
        // ReefAngel.WaterLevelATO( Port7,60,52,58 ); // 60 seconds timeout, turn on at 52% and turn off at 58%
            if ( ReefAngel.LowATO.IsActive())
        if (hour() <= 8 && hour() >= 20)
            vtechmode = 9;
             vtechmode = InternalMemory.RFMode_read();
             ReefAngel.PWM.SetChannel( 0, MoonPhase(0) );
        char text[7];
        ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
        ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
        ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
        ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
        ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
        ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
        ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
        ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
        ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
        ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,10,30,"Temp");
  ConvertNumToString(text, ReefAngel.Params.[T1_PROBE], 10);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,30,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
  ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
        ReefAngel.LCD.DrawOutletBox( 12, 77, TempRelay );
// water level
    ReefAngel.LCD.DrawText(0,255,8,68,"WL:");
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE, 40, 68, 10, ReefAngel.WaterLevel.GetLevel() );
so this makes my ATO PORT 7 just continually cycle instead of remaining on until it reaches the proper %. what am I doing incorrect?
and I can't get water level to display on screen, what's wrong there?
Your coordinates are wrong.
It's printing at coordinates x=68 and y=10.
I think you what you want is this:
    ReefAngel.LCD.DrawText( COLOR_CORNFLOWERBLUE,255, 40, 68, ReefAngel.WaterLevel.GetLevel() );
The code you are using does just that. It will turn on whenever the level goes below 58. There is no hysteresis.
If you want hysteresis, you need to use the previous function you were using before. The one you commented out.
It sounds like from what you want is to use the WaterLevelATO and just increase your timeout... or reduce the high/low difference...
I would suggest something like this.. 3 minutes instead of 1.
ReefAngel.WaterLevelATO( Port7,180,52,58 ); // 180 seconds timeout, turn on at 52% and turn off at 58%
Another thing that will help to put the numbers in a better perspective is.. How long does it take to fill your sump from 52 to 58. That plus a few seconds is what you want your timeout to be.
The code you have everytime it drops to 57 it will turn on till 58 and sometimes the reported level varies from the sensor, so thats why you're seeing on / off / on / off
The other choice is making the numbers smaller. If you want it on at 52%, then leave than and reduce the 58 to something you can get to within 60 seconds.. Say 54%
ReefAngel.WaterLevelATO( Port7,60,52,54 ); // 60 seconds timeout, turn on at 52% and turn off at 54%
bencollinz
now I get this...
    #define Heater      1
    #define Return      2
    #define Skimmer     3
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
byte vtechmode;
        ReefAngel.WaterLevelATO( Port7,600,55,58 ); // 60 seconds timeout, turn on at 55% and turn off at 58%
            // if (ReefAngel.WaterLevel.GetLevel()<58) ReefAngel.Relay.On(Port7);
            // else ReefAngel.Relay.Off(Port7);
            vtechmode = 9;
        char text[7];
// water level
bencollinz
rimai wrote:Your coordinates are wrong.
Thank you, that worked!
I think you already figured out, but just for records...
Your reference to T1 was wrong....
It should be this:
bencollinz
rimai wrote:I think you already figured out, but just for records...
It should be this:
yessir! everything is working so far, have to wait and see about the ATO changes.
bencollinz
Re: My code
for this, how do I require a clear command from RA menu when tripped?
Re: My code
Use the SingleATOLow function
SingleATOLow(Port2);
bencollinz
Re: My code
lnevo wrote:Use the SingleATOLow function
maybe I'm misunderstanding, I changed it to this:
ReefAngel.SingleATOLow(Port2);
and it doesn't turn port 2 off, just changes the status on the portal....?
My code
Did you change that whole section of code? It should go off when the switch is inactive. You may have the switch upside down. Which way is it facing?
bencollinz
Re: My code
lnevo wrote:Did you change that whole section of code? It should go off when the switch is inactive. You may have the switch upside down. Which way is it facing?
the wires are facing up. i removed
and replaced with
again, maybe I'm misunderstanding, sorry.
bencollinz
lnevo wrote:It sounds like from what you want is to use the WaterLevelATO and just increase your timeout... or reduce the high/low difference...
so i changed it back to this format
water went from 61% to now 50% and it didn't turn on even for a blip...ideas?
Re: My code
Are you sure it isn't timed out already?
Just to be sure, can you clear ATO?
bencollinz
Re: My code
rimai wrote:Are you sure it isn't timed out already?
the red light was on, I chose clear ATO it started and wouldn't stop. the red light came on again, I cleared again, it still wouldn't turn off. it's now at 61% again. I had to turn off manually.
current code:
    #define Heater      1
    #define Return      2
    #define Skimmer     3
    #define Vortech1    5
    #define Vortech2    6
    #define ATO         7
byte vtechmode;
        ReefAngel.WaterLevelATO( Port7,600,58,60 );
        // ReefAngel.SingleATOLow(Port2);
            vtechmode = 9;
        char text[7];
  for (byte Left=93; Left < 133; Left+=10)
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, Left, "|");
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, Left, "|");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
// water level
