Moon rise/set implementation
Hey guys,
So, I found this other aquarium controller code at http://code.google.com/p/stilo/ that had ported a javascript implementation of a Moonrise/set calculator into Arduino. I have adapted it to the RA libraries and it looks like it's working great.
Anyway if you want to have your moonlights follow an actual rise/set calculated based on GPS location, then here's what you have to do..
#include Moon.h
And then in your loop() function, add this
moon_init(21,-73); // pass it lat / lon - it uses ints for the caclulation...
You will then have access to the Moon struct which has the following definition:
struct moon_t
  boolean isRise;
  boolean isSet;
  byte riseH;
  byte riseM;
  byte setH;
  byte setM;
  float riseAZ;
  float setAZ;
So you'll be able to do something like this:
  if (Moon.isRise) {
  } else {
    ReefAngel.PWM.SetDaylight(0);
    ReefAngel.PWM.SetActinic(0);
or add this to your display
    sprintf(buf, "%02d:%02d", Moon.riseH, Moon.riseM);
    ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MR:"); x+=21;
    ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf);
    sprintf(buf, "%02d:%02d", Moon.setH, Moon.setM); x+=36;
    ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MS:"); x+=21;
    ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf); x+=36;
    if(Moon.isRise) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"@");
    else ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"_");
Re: Moon rise/set implementation
Cool :)
Just as curiosity, without having to open the h file, did you change it to use our Time.h library??
What is the time that we had moonrise today? :)
Yeah i changed it to use out time library.
Rise and set on my screen:
15:32 4:24
There may be some logic in this i still dont understand because my lights are still on lol.. But the times look ok.
They dont match the page that the source came from, but the times change each day properly...
So maybe not exact but Im not an astronomer :) it does take latitude and longitude..
I'll need to look further why the boolean is keeping my light on right now :)
Alright, I have a fix in, so lights are off at the moment...we'll see if they go on tonight.
There may also be some logic issues when calculating that I may have to review..I may be getting the next days set time while still in the previous days cycle...maybe...
Ok, the moon did rise :) Next I want to see if it calculated set time for tomorrow or if I'll need to wait till after midnight. I'll know when I get home :)
Will also test the new PWMSlope function.
And the moon did set...did not get to see what today's calculation was...I'll have to just wait and see...
The PWMSlope function worked for overnight still :) needs to be checked for standard use now too.
Piper
Post by Piper »
This is very cool, Lee! Are you using the same lat/lon you use for your lighting? I haven't looked too deep into the sunrise/sunset code so not terribly familiar with how that works at the moment.
~Charlie
Yeah, I'm using the same lat / long right now that I'm using for my SunLocation, but they are not tied to each other. So I'm just setting the same variables. I wanted to keep these seperate so they can stand alone...
Well at 4:29pm i have a status of moonlights coming on for today. So thats ~hour diff then yesterday.
I think the offset from real moonrise / set may be from the fact that we do not use any timezone in our clock. I need to test with some other locations and see what the result is.
But it looks like its working. I'll try and test pwmslope with the normal condition and if it works we should be good to go...
New times were 16:24 to 04:58
17:13 to 5:29 for today's schedule...
looks good so far :)
thekameleon
Post by thekameleon »
Not sure if you had updated the code attached. The isRise was true outside the rise to set time range. I tried to figure out what is going on, but I got lost quickly with the code as I could not figure out the meaning of the variables. So I went ahead and use a PMWParabola function with the rise and set times, which is working so far... Do you have an updated code file?
The isRise variable I believe is only used during the test_moon() function. This is why I stopped using it also and did the same thing as you. The issue though, I don't know if the parabola works properly when spanning over midnight. I used a previously published PWMSlopeOvernight which I have modified to work either overnight or not overnight. It should end up in the libraries next update I believe. Is the parabola working properly for you?
Btw, the last code I posted has been updated to the latest and is complete. I haven't done any work on it and it looks like it's working properly. The time is 3 hours off from the coordinates that I am testing with but it could be because we do not really do any time zone on the RA. and the place I have is -3 from GMT... anyway, please test and if you have improvements, I'm all for it. I don't know enough of what's going on and spent like 3 days reading the code to really start tinkering and changing it around. I now have a variable rise/set that matches a moon cylce so I'm happy :)
thekameleon
I'd just like to understand the variable names and what it all means. I haven't seen the PWMSlopeOvernight function, but I wrote this to drive my moon lights.
      byte moonPhase = MoonPhase();
      byte moonPWM = 0;
      if(moonPhase > 0)
        moonPWM = PWMParabola(Moon.riseH, Moon.riseM, Moon.setH, Moon.setM, 10, ((moonPhase / 10) + 11), 0);
My question is around MoonPhase and if I am using it right. It appears the value is an index or in this case 0 - 100, so when it returns 1, I should have the lowest value (dimmest light). Knowing that my MeanWell drivers don't turn on until a value of 11 is sent to them. I adjusted the index according (hence the adding of 11).
Yeah. I just don't know that the PWMParabola function will work properly when PM -> AM versus AM->PM. There was an issue with this in the PWMSlope and so a PWMSlopeOVernight was written. Moving forward there will be one PWMSlope function, but again, not sure on the parabola.
You have the moonphase and params correct it looks like.
thekameleon
I think this should do it:
byte PWMParabolaOvernight(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte oldValue)
        unsigned long Start = previousMidnight(now())+((unsigned long)NumMins(startHour, startMinute)*60);
        unsigned long End = nextMidnight(now())+((unsigned long)NumMins(endHour, endMinute)*60);
        boolean isOvernight=NumMins(startHour,startMinute)>NumMins(endHour,endMinute);
        int Now = NumMins(hour(), minute());
        if (hour()<startHour && isOvernight) Start-=86400;
        if (hour()<startHour || !isOvernight) End-=86400;
        byte PWMDelta = endPWM-startPWM;
        byte ParabolaPhase=constrain(map(Now,Start,End,0,180),0,180);
        if ( Now <= Start || Now >= End)
               return oldValue;
               return startPWM+(PWMDelta*sin(radians(ParabolaPhase)));
I'll let you know in a few days.
Let me find you the thread that I posted the overnight/non-overnight code. You should test with that because moonrise could be within the same day or be an overnight event...
Original PWMSlopeOvernight
http://forum.reefangel.com/viewtopic.php?p=11781#p11781
My Modification to make it universal
http://forum.reefangel.com/viewtopic.php?p=22384#p22384
Lol nevermind... just read your code... looks like you got my changes :)
Roberto.. if this works, both fixes should go in together :)
The slope one is already merged in the dev branch :)
I'll check out the parabola.
thekameleon
So the function did not work. So I tweaked it to this:
        int start = NumMins(startHour, startMinute);
        int end = NumMins(endHour, endMinute);
        if (start < end)
          //Example: 2300hrs to 0200hrs
          if (hour() < endHour) start -= 1440; //past midnight
          if (hour() > startHour) end += 1440; //before midnight
        int current = NumMins(hour(), minute());
        byte pwmDelta = endPWM - startPWM;
        byte parabolaPhase = constrain(map(current, start, end, 0, 180), 0, 180);
        if ( current <= start || current >= end)
          return oldValue;
          return startPWM + (pwmDelta * sin(radians(parabolaPhase)));
This is outputting during a normal non-over midnight. I wish there was a good way to Unit Test Arduino to validate over midnight.
You can, but you will need to modify the libraries.
Would you like to do that?
thekameleon
I was thinking of using Visual Studio for Unit Testing and even building sketches. Visual Micro for Visual Studio actually allows for step through debugging via the serial port. I am not sure how tweaking the libraries would help here, I just want to run the code out side of the controller
I used VS with RA just fine :)
thekameleon
Wow... That was easy.
thekameleon
Here is the function PWMParabolaOvernight. I have been testing it for over a week and it seems to be behaving properly.
  if (start > end) //Start is greater than End so its over midnight
    return oldValue;
Awesome!
Thanks!!!
But it is not working :(
I tested PWMParabolaOvernight(23,0,8,0,10,90,5) and got this:
23	1	5
23	2	5
23	3	5
23	4	5
23	5	5
23	6	5
23	7	5
23	8	5
23	9	5
23	10	5
23	11	5
23	12	5
23	13	5
23	14	5
23	15	5
23	16	5
23	17	5
23	18	5
23	19	5
23	20	5
23	21	5
23	22	5
23	23	5
23	24	5
23	25	5
23	26	5
23	27	5
23	28	5
23	29	5
23	30	5
23	31	5
23	32	5
23	33	5
23	34	5
23	35	5
23	36	5
23	37	5
23	38	5
23	39	5
23	40	5
23	41	5
23	42	5
23	43	5
23	44	5
23	45	5
23	46	5
23	47	5
23	48	5
23	49	5
23	50	5
23	51	5
23	52	5
23	53	5
23	54	5
23	55	5
23	56	5
23	57	5
23	58	5
23	59	5
0	0	37
0	1	37
0	2	37
0	3	38
0	4	38
0	5	38
0	6	39
0	7	39
0	8	39
0	9	41
0	10	41
0	11	41
0	12	42
0	13	42
0	14	42
0	15	43
0	16	43
0	17	43
0	18	45
0	19	45
0	20	45
0	21	46
0	22	46
0	23	46
0	24	47
0	25	47
0	26	47
0	27	48
0	28	48
0	29	48
0	30	50
0	31	50
0	32	50
0	33	51
0	34	51
0	35	51
0	36	52
0	37	52
0	38	52
0	39	53
0	40	53
0	41	53
0	42	54
0	43	54
0	44	54
0	45	55
0	46	55
0	47	55
0	48	57
0	49	57
0	50	57
0	51	58
0	52	58
0	53	58
0	54	59
0	55	59
0	56	59
0	57	60
0	58	60
0	59	60
then I went and tested PWMParabolaOvernight(22,0,8,0,10,90,5) and got this:
22	1	5
22	2	5
22	3	5
22	4	5
22	5	5
22	6	5
22	7	5
22	8	5
22	9	5
22	10	5
22	11	5
22	12	5
22	13	5
22	14	5
22	15	5
22	16	5
22	17	5
22	18	5
22	19	5
22	20	5
22	21	5
22	22	5
22	23	5
22	24	5
22	25	5
22	26	5
22	27	5
22	28	5
22	29	5
22	30	5
22	31	5
22	32	5
22	33	5
22	34	5
22	35	5
22	36	5
22	37	5
22	38	5
22	39	5
22	40	5
22	41	5
22	42	5
22	43	5
22	44	5
22	45	5
22	46	5
22	47	5
22	48	5
22	49	5
22	50	5
22	51	5
22	52	5
22	53	5
22	54	5
22	55	5
22	56	5
22	57	5
22	58	5
22	59	5
23	0	34
23	1	34
23	2	34
23	3	34
23	4	36
23	5	36
23	6	36
23	7	37
23	8	37
23	9	37
23	10	38
23	11	38
23	12	38
23	13	38
23	14	39
23	15	39
23	16	39
23	17	41
23	18	41
23	19	41
23	20	42
23	21	42
23	22	42
23	23	42
23	24	43
23	25	43
23	26	43
23	27	45
23	28	45
23	29	45
23	30	46
23	31	46
23	32	46
23	33	46
23	34	47
23	35	47
23	36	47
23	37	48
23	38	48
23	39	48
23	40	50
23	41	50
23	42	50
23	43	50
23	44	51
23	45	51
23	46	51
23	47	52
23	48	52
23	49	52
23	50	53
23	51	53
23	52	53
23	53	53
23	54	54
23	55	54
23	56	54
23	57	55
23	58	55
23	59	55
0	0	57
0	1	57
0	2	57
0	3	57
0	4	58
0	5	58
0	6	58
0	7	59
0	8	59
0	9	59
0	10	60
0	11	60
0	12	60
0	13	60
0	14	61
0	15	61
0	16	61
0	17	62
0	18	62
0	19	62
0	20	63
0	21	63
0	22	63
0	23	63
0	24	64
0	25	64
0	26	64
0	27	65
0	28	65
0	29	65
0	30	66
0	31	66
0	32	66
0	33	66
0	34	67
0	35	67
0	36	67
0	37	68
0	38	68
0	39	68
0	40	69
0	41	69
0	42	69
0	43	69
0	44	70
0	45	70
0	46	70
0	47	71
0	48	71
0	49	71
0	50	72
0	51	72
0	52	72
0	53	72
0	54	73
0	55	73
0	56	73
0	57	73
0	58	73
0	59	73
Looks like it is missing the starting hour completely.
Here is the test code I used:
int test=0;
  ReefAngel.Init();
  wdt_reset();
  adjustTime(60);
  Serial.print(hour());
  Serial.print("\t");
  Serial.print(minute());
  Serial.print("\t");
  Serial.println(PWMParabolaOvernight(22,0,8,0,10,90,5));
  delay(10);
  if (test++>2500)
  while(1) wdt_reset();
    return oldValue;
The only thing is that you will need to change the libraries to perform this test.... :(
You need to change ReefAngel.cpp
From
	setSyncInterval(SECS_PER_HOUR*6);  // Changed to sync every 6 hours.
To
	setSyncInterval(SECS_PER_HOUR*6000);  // Changed to sync every 6 hours.
Or the clock will keep syncing with the RTC.
thekameleon
I was just testing if you were actually paying attention.... :D
I think my problem is this line:
Change it to this
if (hour() >= startHour) end += 1440; //before midnight
Awesome!!!
I'll include in the next update :)
