Wave patterns
PostPosted: Thu Mar 21, 2013 12:38 pm
I'd like to start a thread to collect all the efforts of creating wave patterns for controllable pumps.
These functions can be used for either Tunzes or Jebao pumps.
This list will keep being updated as we code more and more functions.
Short Pulse
PulseMinSpeed - % for minimal speed
PulseMaxSpeed - % for maximum speed
PulseDuration - Duration (milliseconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
PulseSync - true if you want to sync pumps to same cycle. one false and one true if you want to anti-sync pumps.
byte ShortPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  PulseMinSpeed=constrain(PulseMinSpeed,30,100);
  PulseMaxSpeed=constrain(PulseMaxSpeed,30,100);
  tspeed=(millis()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
    return (tspeed==PulseMinSpeed)?PulseMaxSpeed:PulseMinSpeed;
Long Pulse
PulseDuration - Duration (seconds) in which each pulse will be held. The pump will stay at minimal speed for PulseDuration and will stay at maximum speed for PulseDuration.
byte LongPulseMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  byte tspeed=0;
  tspeed=(now()%(PulseDuration*2)<PulseDuration?PulseMinSpeed:PulseMaxSpeed);
  if (PulseSync)
    return tspeed;
Sine
Contribution of Discocarp
viewtopic.php?f=2&t=2386&p=18240
PulseDuration - Duration (seconds) in which the entire sine wave will take to complete.
byte SineMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync) {
  double x,y;
  x=double(now()%(PulseDuration));
  x/=PulseDuration;
  x*=2.0*PI;
  if (!PulseSync) x+=PI; // shift the sine wave for the right pump
  y=sin(x);// y is now between -1 and 1
  y+=1.0; // y is now between 0 and 2
  y/=2.0; // y is now between 0 and 1
  // now compute the tunze speed
  y*=double(PulseMaxSpeed-PulseMinSpeed);
  y+=double(PulseMinSpeed);
  y+=0.5; // for proper rounding
  // y is now between PulseMinSpeed and PulseMaxSpeed, constrain for safety
  return constrain(byte(y),30,100);
ReefCrest
WaveSpeed - % for average speed
WaveOffset - Max offset of speed in which the mode will go up/down from average speed
byte ReefCrestMode(byte WaveSpeed, byte WaveOffset, boolean PulseSync)
  static unsigned long lastwavemillis=millis();
  static int newspeed=WaveSpeed;
  if ((millis()-lastwavemillis) > 5000)
    if (random(100)<50) newspeed--; else newspeed++;
    newspeed=constrain(newspeed,WaveSpeed-WaveOffset,WaveSpeed+WaveOffset);
    newspeed=constrain(newspeed,0,100);
  if (PulseSync)
    return newspeed;
    return WaveSpeed-(newspeed-WaveSpeed);
Nutrient Transport
byte NutrientTransportMode(byte PulseMinSpeed, byte PulseMaxSpeed, int PulseDuration, boolean PulseSync)
  static byte WavePhase=0;
  static time_t WaveStart=0;
  static byte speed=PulseMinSpeed;
  static byte anti_speed=PulseMinSpeed;
  if (WavePhase==0)
    WavePhase++;
    WaveStart=now();
  else if (WavePhase==1)
    if (now()-WaveStart>2700)
      WavePhase++;
    if ((millis()-lastwavemillis) > PulseDuration)
      if (speed==PulseMinSpeed)
        speed=PulseMaxSpeed;
        anti_speed=PulseMaxSpeed;
  else if (WavePhase==2)
    if (now()-WaveStart>4500) WavePhase++;
    if (now()-WaveStart<=2760)
    if (now()-WaveStart<=3300)
      anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,3300,4500,0,180)));
  else if (WavePhase==3)
    if (now()-WaveStart>7200) WavePhase++;
  else if (WavePhase==4)
    if (now()-WaveStart>9000) WavePhase=0;
    if (now()-WaveStart<=7260)
    if (now()-WaveStart<=8400)
      anti_speed=PulseMaxSpeed*sin(radians(map(now()-WaveStart,7200,8400,0,180)));
      anti_speed=0;
  if (PulseSync)
    return speed;
    return anti_speed;
Tidal Swell Mode
WaveMaxSpeed - % for maximum speed
byte TidalSwellMode(byte WaveMaxSpeed, boolean PulseSync)
  static byte speed=0;
  static byte anti_speed=0;
  if (WavePhase==0)
    WavePhase++;
    WaveStart=now();
    if (now()-WaveStart>900) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,0,900,0,90))))/10;
    speed+=WaveMaxSpeed/2;
    anti_speed=(WaveMaxSpeed*2*sin(radians(map(now()-WaveStart,0,900,0,90))))/5;
    anti_speed+=WaveMaxSpeed/2;
    if (now()-WaveStart>1800) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
    speed+=WaveMaxSpeed/20;
    anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,900,1800,90,180))))/20;
    anti_speed+=WaveMaxSpeed/4;
    if (now()-WaveStart>2700) WavePhase++;
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,1800,2700,0,90))))/20;
    if (now()-WaveStart>3600) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
    speed+=(WaveMaxSpeed*3)/20;
    anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,2700,3600,90,180))))/20;
    anti_speed+=(WaveMaxSpeed*3)/20;
  else if (WavePhase==5)
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,3600,4500,0,90))))/20;
  else if (WavePhase==6)
    if (now()-WaveStart>5400) WavePhase++;
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
    speed+=(WaveMaxSpeed*5)/20;
    anti_speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,4500,5400,90,180))))/20;
    anti_speed+=WaveMaxSpeed/20;
  else if (WavePhase==7)
    if (now()-WaveStart>6300) WavePhase++;
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,5400,6300,0,90))))/20;
  else if (WavePhase==8)
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/20;
    speed+=(WaveMaxSpeed*7)/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,6300,7200,90,180))))/10;
  else if (WavePhase==9)
    if (now()-WaveStart>8100) WavePhase++;
    speed=(WaveMaxSpeed*3*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/20;
    anti_speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,7200,8100,0,90))))/2;
  else if (WavePhase==10)
    speed=(WaveMaxSpeed*sin(radians(map(now()-WaveStart,8100,9000,90,180))))/2;
    anti_speed=speed;
  if (PulseSync)
    return speed;
    return anti_speed;
Tide Mode
Contribution of lnevo
viewtopic.php?f=11&t=2708
minOffset - minimum offset between high/low tide
maxOffset - maximum offset between high/low tide
byte TideMode(byte WaveSpeed, byte minOffset, byte maxOffset)
  // Contribution of lnevo
  double moonOffset; // gap between high and low
  double amplitude;  // tide curve
  double wavelength=12*SECS_PER_HOUR;
  // Calculate the gap between high and low tide based on MoonPhase()
  moonOffset=cos(((2*PI)/100)*MoonPhase());
  moonOffset=((moonOffset+1)/2)*100; // Convert to percentage
  // Find out the current tidal height
  amplitude=sin(((2*PI)/wavelength)*now());
  moonOffset=map(moonOffset,0,100,minOffset,maxOffset);
  amplitude=amplitude*moonOffset;
  // Adjust the calculate speed to be in our adjusted range
  return constrain(WaveSpeed+amplitude,0,100);
PostPosted: Thu Mar 21, 2013 12:46 pm
The tide simulation class could be counted as a "constant" wave pattern similar to the Sine wave function above. It returns a constant speed that gives a high tide and low tide effect every 12 hours. The minOffset is the difference between high and low tide during quarter moons and the maxOffset is the difference at new and full moon.
Tide mode:
Speed - base midline speed for wave
minOffset - minimum gap between high/low tide
maxOffset - maximum gap between high/low tide
#define PI 3.141593
byte TideMode(byte Speed, byte minOffset, byte maxOffset) {
  amplitude=sin(((2*PI)/waveLength)*now());
  return constrain(Speed+amplitude,0,100);
Also should note that these functions could also be used with the Vortech custom mode :)
Edit: Updated to fix the broken map (did not like 0-1)..
PostPosted: Thu Mar 21, 2013 1:33 pm
fantastic! I like info on one page!
PostPosted: Thu Mar 21, 2013 2:35 pm
Very nice! Thanks, Roberto!!
PostPosted: Thu Mar 21, 2013 5:08 pm
Awesome. Thank you.
PostPosted: Fri Mar 22, 2013 7:10 am
Thanks this is awesome.
PostPosted: Fri Mar 22, 2013 12:38 pm
Roberto, this is a great idea! You are really going to save new Reef Angel users a lot of time with this post. Thinking back on the countless hours that I spent researching this information in various threads when I got my Tunze powerhead.
PostPosted: Sun Mar 31, 2013 4:58 am
excellent resource
PostPosted: Sun Mar 31, 2013 1:08 pm
So does anyone have a favorite yet?
PostPosted: Mon Apr 01, 2013 5:54 pm
So is reef crest just a slow ramp up and down to the predefined range?
Seems to slow for me. Would like it to change values up and down faster.
Are there any aggressive modes? I loved the else mode.
Next
